*** The Official Destiny Thread (now includes 2.0 and TTK) ***
it's been so long since i've done it, i'm getting confused with nightfall timer.
you want to be going clearing the tank room with 5 mins to go as you make your way to the final room. and i must have done it with at least a minute to spare every time. so it's easily do-able. it's people going in there with no strat at all other than shoot that will struggle.
sword strat is the easiest one, we tried the 3 celestial nighthawk strat once and it was much harder.
I honestly don't know what crack Bungie is smoking when they said "Atheon is the hardest challenge we've ever done".
Aksis is so dependant upon communication and exact timings, the margin for error is extremely thin, we wiped so many times with literally milliseconds of difference between discharging in the plate and stunning Aksis.
I can say with absolute honesty that I am never, ever, doing that challenge again.
If you've managed to do it on 390.. pat on the back. It's probably the hardest thing I've done since Mile High Club..
Props to Rooster for not choking, like I did one run, and getting the final slam.
Thank the lord!!!
I felt all the tension again just watching that, all the stress was worth the buzz of killing him in the end.
Here's my perspective:
Dat WOTM Aksis challenge mode though. If your a second off its a wipe.
Finally got him down with Parsnip and some Reddit LFGs though after a lot of trying. Just Atheon and Deathsinger challenges to do now.
What happened to Davie? Assume your tinternet went down. You saved yourself some stress hehe.
Internet did kick me off but when I got back on I couldn't log into PSN....... no idea why.
Wrath armour drops have not been kind to me. I have never got the spliced chest piece on my WL. I have also never got either class item... sodding artefact every time!.
I might be on tonight for Crota but I am feeling as rough as anything.
I don't believe there is an actual running order for tonight...
So I'm guessing it will be:
  1. Par5n1p
  2. Mach M
  3. TX0409
  4. DavieM66
  5. TL_Venom
  6. Red Rooster
Thats two groups for a nightfall too.. from 7pm?
Cleetus.. I'll help you out with Crota too :)
Yeah I won't be on tonight chaps. Big upheavals (again) at work so I won't be in the right frame of mind. JP (and Parsnip from memory) is good with the sword so you shouldn't have any issues getting the challenge done. :)
Will be on later in the week if anyone wants another run.
Yeah we could use the double bubble strat, Blessings up top with someone inside to keep the boomers occupied and a weapons on the rock so we can get him down using just 2 sword bearers :)
I would suggest if you are going 2 sword have your first sword bearer attempt to get him under 50% health (R1, R2,R2,R2 + R1,R2,R2 & R2 Super should take 60% of his health bar). This should avoid the randomness we had when doing it back in wk1. :)
EDIT: This is the strat we were running JP with the double bubbles as you suggest. Have a hunter with CH be responsible for the OS and you should have no issues.
