If they're ones you've created yourself you can export them to a file, to which you can re-import later. I think if you click on the profile name in the top left there's an icon with two arrows, I believe from there you can export (and later import) your profile/settings.
I would check the Corsair site to see if CUE has been updated to a newer version - I can't get the tool in the program to check for updates, it always fails.
Looking to finally move on from my trusty Sidewinder X4. Can't decide between the K70 LUX or the Rapidfire model. I'm more of a gamer so assume rapid fire would be the better option?
I bought the Red switch K70 LUX RGB, as from doing a bit of poking about the internet that's the generally preferred switch for gaming. I've had it for around a month or so, and it's excellent. I haven't tried a Rapidfire so i'm afraid I can't compare but in terms of feel it's very responsive, really defined keypresses compared to a rubber dome and to be honest it's not that loud. When CUE works the amount of lighting options is astounding, makes for some amazing lighting combinations.
I don't know if anyone else has experienced this, but I've noticed a little pattern when plugging in/unplugging my VOID wireless headset to charge. CUE decides my K70 LUX has malfunctioned, and there's no lights on it whatsoever (it still types) - my M65 PRO is fine, though. I need to restart CUE and it then sorts itself out.
My keyboard has started to do it again
Greybeard can you sort this out please?
hey guys, sorry for not getting back to you guys sooner. Just got back from a personal PTO. I am sorry to hear that you guys are still having some issues. Since these were posted a few weeks back, I am just curious if you guys are still dealing with those issues. And in case you didn't know, there is a new version of CUE that recently came out. So if you haven't already done so, please give it a shot and see if the latest version would sort it out. If not, let me know.
