yes but if i buy say 2 AC-lites, I also need to buy a router then also a POE switch or use injectors. I also then need to run wires everywhere. the costs now start to rack up.
doesn't make any sense to do all that when my main server/htpc is in the same room as the router so will be hard wired in anyway. the only other things i care about are 2 consoles and a gaming PC, and ping isn't an issue, neither is speed with google wi-fi.
also those access points are designed with 50 devices being connected in mind. not 10. it excels where you need 50 devices connected, if you only need 10 then it's pretty pointless.
like i say the small net builder reviews don't exactly scream out to me that i need to go out and buy ubiquiti gear. also i was thinking about CCTV then i would definetely go down the POE switch route but again it's overkill for my usage. I don't need CCTV either.
i'm going to leave my setup as is for now. nothing atm is screaming out as a must buy. i fixed my wifi range issue with the use of a asus wireless extender which my gaming pc and consoles are hardwired into.
You don't need a Unifi router to run multiple APs on Unifi. You just plug them into your existing router or Uplink one to another. Yes, they need power, but so do the Google WiFi units or even your ASUS range extender. And I suspect if you just bought your kit once, it would be the same price or less.
