Sorry to be the bearer of bad news, but they're comparing "Vega" vs NVIDIA while NV is on OS X, while Vega is on Windows.
The results are being skewed as a result.
Architectural improvements.The worrying thing for me is that with the RX580 AMD and/or GF has shown there is basically zero improvement in the process. Then again, GF even states that the latest 14nmFF+ has improvements in production costs but not in performance. And with the RX580 there eems to be different ASIC qualities with only some chips making the highest speeds which suggests to em there are sitll process problems.
So then it comes down to how likely a bigger, more complex chip than Polaris 20 going to hit the clock speeds? P20 runs at 1257MHz base clock and is often pulling about 220W during gaming and power increases rapidly with over-clocks. Vega is getting built on the same process. the MI25 was reportedly using 300W for 1.5GHz according to AMD specs, I'm really doubtful AMD want to put a 300w gaming GPU out.
It isn't best. Ie Ryzen is not getting to 5GHz on air, and Polaris clocks are nowhere near Pascal. But it is good.
Maxwell saw a huge reduction in necessary power draw on the same process as Kepler. Not saying we'll see the same leap here, but efficiency improvements could easily give them room for going bigger and faster without running into power ceilings.
Didn't know Johnny Vegas was a PC enthusiastsnip
Joker Vid
+1Main issue with that video, he's using WCCFT as a source.
If process shrinks stopped, there'd still be improvements in architectures for quite a while. Obviously diminishing returns would come into play pretty quickly, but there is not some strict limit on how much architectures can improve.There is a limit to how much architectural improvements are possible on the same process. Maxwell achieved a lot by massively cutting down Fp64 support to 1/32, Polaris (and Fiji) has already done that. Maxwell chips also got larger, so the 980ti chip was bigger than the 780ti while the chip size of the vega as picture is similar to the 1080ti (475 vs 471mm^2). Furthermore, the 28nm process used by Maxwell had undergone a lot of refinements and improvements but ti doesn't appear to be the case withe the GF 14nm process.
But yes, the real change will be architectural improvements. Maxwell achieved about a 30-35% boost but that was really quite remarkable. 35% can be achieved by cutting support for FP64, increasing die size 13%, decent process improvements and architectural improvements. AMD have the latter in their favor.
And you're right, Maxwell chips got larger. Yet drew even less power compared to the smaller Kepler chips, especially at the mid/upper mid range level, really showing that Maxwell's architectural efficiency improvements were even bigger than many really think.
I also agree Maxwell's improvements were remarkable, but my point is that you cant just look at Polaris and say, "That's it, that's what we have to scale TDP estimates on when talking about Vega". I'm not making any predictions myself, I dont know what will happen, but theoretically, notable efficiency gains are totally possible.
With your keyboard and mouse in your backpack?
Or you mean like a games console?
If it's clocked at 1200MHZ, then yeah 1070 performance would be realistic
Being negative or positive about AMD doesn't have any effect whatsoever on what AMD actually puts out if we're just talking us regular folks. No amount of praise and positive thinking will make Vega any better than it will be.
It's also very possible to want AMD to do well yet still be negative about how you'll think they'll do. Hopes vs realistic expectations - they are not the same thing.
As there is no sound news on vega just yet cant we do what we did in the Ryzen thread and make up a load of random rubbish so that WCCFT read it and report it again ?that was epic haha
Lol, it doesn't quite work like that. On paper looks like roughly double the specs of the 480 so lets double the FPS of the 480. double the computer power of the 480 is 11.6Tflops which is around the compute power of the 1080ti at stock clocks but we all know it boosts way higher than that on its own meaning its faster. Every 1080ti will boost higher than this meaning a 1080ti is more like high end 13 to 14 Tflops of performance.
This guy has 480x2 (Vega) at either same or slightly faster than 1080ti.
It's going to be more likley slightly faster than a 1080 but falling short of a 1080ti.
Would be nice if true. But just seems like another fake.Vega launch next week 9 May 2017 and NDA lift this Sunday on 8 May 2017?
http://www.overclock.net/t/1629599/various-full-vega-faster-than-titan-xp-in-4k-release-date-may-9th
