Would plugging in all 3 8 pins be detrimental to the performance for non-overclockers? Lets say I already have some custom sleeved cables that I want to show off, the GPU will only pull the voltage needed, correct? So no harm could come of it? Same question for my mobo, it has an 8 pin and a 4 pin for CPU Power, I wanted to plug into the 4 pin aswell, is this fine if I don't intend to extreme overclock?![]()
No it would not be detrimental to the performance. It could possibly make the card draw ever so slightly a few extra watts but nothing that would affect performance. The card will only draw as much power as it needs at the set voltage so if you just max out the power slider and don't overclock the card you'll probably sit at around 2Ghz and draw upto 300watts of power on full load at stock volts.
make sure you have at least the 8pin (2x4pins) in the CPU motherboard header. The extra 4 pin if its at the top of the motherboard will most likley be for helping with CPU overclocks though i doubt it would need it unless once again LN2 overclocking. Or it could quite possibly be for the PCI_E lanes to provide more power to 3-4 way cards in SLI/Xfire.
If your not planning on overclocking this card certainly is not you for lol. Even for people with general overclocking in mind this card is overkill and won't guarantee them overclocks better than say for example the Zotac AMP extreme. FOR LN2 Overclockers this card would be way more appealing.
And I have no other phones available to me in the super early morning since there is a 10 hour difference lol. Alas, I shall find a way!
