Monitor Upgrade.
14 Apr 2011
Stafford
Not sure this is the correct part of the forum but it does say upgrade advice so here goes.
I have about £400 to spend on a new monitor.
Currently I am using a Dell Ultrasharp U2311H 23" Widescreen LCD Monitor - Midnight Grey
that is 6 years old now!.
I mainly use it for gaming and will be using a 970 initially to run it but will probably upgrade that to a 1070 when funds allow but I think that might be some time away just yet. Ideally I want something that is will work well with the 970 but will last me through to the 1070 when I do upgrade.
OP
14 Apr 2011
Stafford
Thanks Stulid.
Are there any good 27 inch panels like that if i could increase the budget to say £500?
I think the aoc is ideally for me but not sure if i should take this opertunity to step up the size?
OP
14 Apr 2011
Stafford
Just noticed that the 4k version of the same monitor is currently only £50 more :
https://www.overclockers.co.uk/aoc-...descreen-led-monitor-black-red-mo-04c-ao.html
I suppose that would future proof me even more and I can still game at the normal 1440p resolutions.
Is that a good idea? whats it like gaming on a 4k screen? I would imagine I would notice a lot of difference from my current setup.
Will the 970 drive that ok for say the next 12 months or so? I mainly play wow currently so its no that taxing on the GFX card I dont think, but I do sometimes play the odd game of
heroes of the storm and overwatch.
Caporegime
17 Jan 2010
weston-super-mare
I have not used a 4K screen.
But A single GTX970 is going to struggle, Gsync will help smooth the frame rate etc, but that is a lot of pixels for it to push around.
Luckily as you said the games you are playing dont look the most advanced GFX wise.
31 Dec 2007
The TARDIS, Wakefield, UK
With a GTX 970 you are looking at med to high settings and it will struggle a bit with a 4k screen. Even a 1070 is not ideal and IMHO 1440p on a 4k screen looks awful. You would be better off going for the IPS one in #4.
To be honest I dont see the point in going for a 4k screen unless you have a decent graphics card and are going to use it at its full potential and you are looking at 1080 or a 1080ti.
I was okayish with a 980ti (which is about a 1070) but I am glad I went back to a 1440p.
OP
14 Apr 2011
Stafford
Ok,
So, having had a bit of a chat with the wife. I would appear that I can afford to spend a little bit more on my PC.
Currently I have the following:
Intel Core i5 2500K 3.30GHz
XFX 750W Black Edition Modular Power Supply
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card
Kingston HyperX 3K SSD 240GB 2.5" SATA 6Gbs Black White Finish (KE-S32240-W)
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) + which I added to the previous 2x4gig so now have 12gig (2x2 and 2x4)
Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW)
What would be the best way to spend around £600 on that system to improve it? given the above I am thinking perhaps 8 gig memory to take it to 16gig and a 1070 along with a new monitor? and perhaps if funds allow a new ssd??? fire way with recs please :)
OP
14 Apr 2011
Stafford
Is the 2500K overclocked?
It was clocked to run `out of the box` from overclockers at 4.4GHZ, I have never had a stable system running it at 4.4ghz even on the newer H100i (it was supplied originally with a cheap air cooler) I can get it to run at around the 4Ghz mark and it remains stable (when I say stable I actually never shut down my PC it runs 24/7) when I am gaming I can obviously hear the fans spin up more.
I have the same motherboard and cpu combo running 24/7 for pretty much 6 years but I have no issue with keeping it like that if the money is best spend elsewhere, obviously in the process of upgrading everything I will take it all apart give it a good clean out and put it back together.
19 Apr 2003
How have you clocked the CPU BIOS or software?
And is that £600 for the gfx/memory/ssd and monitor - or is there a separate budget for the monitor?
19 Apr 2003
You had a considerable budget for few components - so opted for a quality 27" monitor as this seems to be the size you were favouring in previous posts.
I also added 2 x 8Gb of memory as you 'should' defiantly be able to retain your clock with just 2 sticks - as 4 sticks can add complications to existing clocks (plus i think we maybe able to get your clock higher - no guarantees).
I haven't added an SSD - unless you were after a larger model?
My basket at Overclockers UK:
Total: £1,090.67
(includes shipping: £11.70)
I will add that if you didn't upgrade your monitor/memory - you would have the funds for a quality Ryzen build.​
OP
14 Apr 2011
Stafford
Understood. but I have been gaming at 1080p for the last 6 years and want to make the next step up. If I can build a nice Ryzen build in say 12 months or so then the items I get now will hopefully see me through at least until I build my next pc. I am somewhat reluctant to spend 130 quid on new ram if I am honest but if that carry over to a new build it might be an investment?
19 Apr 2003
Totally valid - and decent monitor upgrade is a great new toy - was making you aware just in case.
No it wont transfer - Ryzen uses DDR4. So i would get another 2 x 4Gb and hope your clock holds - it should.
OP
14 Apr 2011
Stafford
Plec, thanks for your time.
If I could say add another 600 quid to the pot. What would be the decent ryzan bulid that you would recommend? given that I dont need a case or PSU?
19 Apr 2003
I've added 3200MHz memory as i've got 2 sets of this memory running at 3000MHz and I'm hopeful of hitting 3200MHz with tweaks (especially with future BIOS updates) - can't guarantee yours will - but you can change this to Team Group 3000MHz memory at only £120.
Below is a guide - and is well below your £1800 budget (1200 + your additional £600 you suddenly found :)). So you could add another SSD or even Ryzen 1700 - but if this is a gaming rig Ryzen 1600 is the bang for buck.
Total: £1,426.55
(includes shipping: £12.60)
