Our eyes are not letterboxed... We do not "see the world" in 21:9. Lol
16:9 is about as close you can get to what is "human vision".
Have a read about it.
A 16:9 screen (if big enough) will near perfectly fill your vision .
A 21:9 will leave gaps top and bottom.
Facts.
+1 HahahahahaHe just needs to upgrade his potato pc mate and drop that rubbish ulrawide poop that is rarely optimised properly for gaming.![]()
Have I rustled some jimmies from you 16.9 peasants?Don't be jelly of the master race
Again, resolution and aspect ratio are 2 different things, you could have high resolution and 21.9 aspect ratioGive me the superior aspect ratio over pixels any day of the week though
I thought you had issues too?
At least it read like you did anyway.
No way am I doing a format for a broken game (especially when every other game on my system runs perfectly, even mafia 3 runs amazingly well now.....), I can get the light shaft rays back by using the overall preset setting of very high, not my problem if developers can't get their game to work, heck what can you expect from Bethesada though, they couldn't even get a basic resolution setting to work on release for fallout 4.....
*facepalm*
16.9 is not a resolution, it is an aspect ratio
Tell that to people on here:
https://www.reddit.com/r/ultrawidemasterrace/
I've seen more people go from "4k" to 21.9 than the other way round.
I've used all kinds of displays, 4k in both 16.9 27-55" and 21.9 screens, in terms of just immersion, you can't beat 21.9, it is just better.
But once again, people really need to stop just thinking "4k" is what makes screens look sharp etc. It is is completely down to the PPI (which is brought from a higher resolution) and viewing distance, superb article that explains this here:
http://www.anandtech.com/show/7743/the-pixel-density-race-and-its-technical-merits
I will be getting an 55" 4k OLED HDR TV soon, however, I will be putting a custom 21.9 res. on it so as to avoid the cramped look of peasant 16.9 for gaming
My potato PC runs well optimised games fantastically, I ain't going to throw away £500+ just for a few more FPS and to run "ultra" that brings no benefit to IQGot better things to spend my money on
Heck, I'm even happy with my 290s performance, the only reason I'm wanting to upgrade is for a cooler and quieter running GPU![]()
Not often I agree with you but on this rare occasion, 100% correct.21.9 is the master race, 16.9 is for peasants, time to move on to the future![]()
You keep telling yourself that because you paid over the odds for a fad aspect ratio. 16:9 fills more of your vision if a good size and is MORE immersive. Not less. Obviously I mentioned 4k because to be immersive you need a big screen and be close to it. And if you want to be close to it you need it to be 4k.
16:9, big, 4k screens are unquestionably the future. There is a reason 16:9 has taken off as the most popular aspect ratio. Because it's the best for our eyes for immersion. You my friend have just been gobbled up by clever marketing.
Sure your 21:9 will look better than a 16:9 of the same size. But a bigger 16:9 is just more immersive. You don't loose that vertical real estate.
Preach it brutha! Praise the ultrawide master race! Amen y'all!
Seriously though. 21:9 > all
Just get both? Easy!
Facts.
Only jimmies getting rustled here is your bra
I did have issues with a couple of missions where the tracking was broken. Usually that would not bother me, but when you have to go outside a space station which is huge and look for a small bot, it can get annoying. I found him in the end not so long after starting to get annoyed though. That said they said they fixed that issue now apparently. Other issue is losing fps after the patch which is still the case. None of this stopped me from enjoying playing the game though
As for monitor's, yes PPI is important, I know, my PPI is 163
People that say they do not see it either do not wish to see it, made erroneous comparison with mismatching PPI (i.e. compared a huge 4K screen to a small 1440p monitor, maybe tried the wrong game out which did not highlight it or needs to go specsavers
Trust me, if there was little to no difference I would much rather the extra fps at 1440p and would save the money by not needing an expensive graphics card, but there is clearly a difference in many games, some more than others.
But 4K is the future for the majority, as consoles are moving that way and TV's are pretty much 4K as a standard now.
I imagine things will change once we get 4k panels that go beyond 60hz and once the hardware to handle 4k is cheaper.
I'm on a 75hz 34" 3440x1440 and it's great but if I could get a 40" 100hz+ 4k model with the equivalent freesync capabilities I'd be interested.
I remember when I upgraded to 1440p in 2011 I felt it was a little early as GPU's were still not able to draw it at good FPS. I'd personally hate to upgrade to 4k now for the same reason. I just want to play games at max settings, I can't be at**ed adjusting settings to get a smooth framerate. Only recent years I've felt top end GPU's were good enough for 1440p!
Reckon it's another 2 years ago least before I'll be going 4k. Until then I'll be rockin' with a Dell U2711 unless it fails then will probably go 4k
+1Yup I will just hold of playing the game till it is all patched up, got mafia 3 to complete now.
Once games properly support resolutions higher than 1080P, the difference will be even more noticeable.
Again, "4k" is not limited to 16.9... Aspect ratio and resolution, 2 different things
Yup it can be a right PITA to adjust settings etc. but it is well worth it as not only do you get a game that runs better but can often look better too
I actually find 21:9 at the cinema a bit annoying. It is too wide. Hard to find a sweet spot where to sit. To close and your eyeballs and even neck has to wonder about, too far and things look to small and less enjoyable. My experience anyway.Lol. The reason film is shot in 21:9 and not something closer to 16:9 is not because it is more immersive. It's because you can get more people in the cinema and more people can watch it at once! That's why it's so wide. It's easier to make a cinema wider than have two teirs.
Thanks, will check it out soonThis is a fantastic video on the history of Aspect ratios through the years.
Again, "4k" is not limited to 16.9... Aspect ratio and resolution, 2 different things![]()
16:9 was around in the TV market in the early 2000s, far earlier than pretty much anything except 4:3. I am not really sure why 16:10 became popular in the late 2000s for PC monitors but when TVs started getting flatter and bigger they obviously realised it'd save money to make most panels the same aspect ratio. Plus I guess it helps for watching video...something phones and tablets didn't really realise early on either.However, we can definitely agree that 16:9 will be the standard going forward largely because of the Television market. 16:9 didn't take off massively as a resolution until the TV market pushed it and I can't see the TV market adopting 21:9 as virtually all TV programming is shot at 16:9. As gamer's though, we're not limited by the TV market and we should go for the most immersive technologies as games are not stuck at a fixed ratio - and it's impossible to argue that 16:9 is more immersive than 21:9![]()
Say what you will Nexus. 21:9 will never become mainstream. Games will always be designed primarily for 16:9. Don't fight it. Join the 4K master race
(HUD [which really annoys me] and cut scenes aside)
Film is shot in what the director chooses, not 21:9/2.35:1/2.37:1 etc. It's artistic choice, so do not blanket statement films with regards to aspect ratios. Do all painters use the same size/aspect canvas? I think not.
Obviously but that isn't the point I was making, For many people like myself a bigger screen will need a higher resolution to look good still, you made my point with the bit about your 1080p phone screen, If I'm ever going to consider getting a 40"+ 16:9 monitor it'll have to be 4k so that it looks good, add to that a higher hz and that was my point. At the moment there's nothing that'd make me reconsider using a 21:9 monitor but once we have monitors offereing the mentioned specs I would consider moving back to 16:9. That said I would be more likely to go with a 40"+ 21:9 uw4k (5---x2160) if that's also available.
