- 4 Nov 2006
- Yorkshire
mrk - would you recommend the S8 then?
I'm currently using a Nexus 6 but the charging port is buggered and i'm itching to upgrade anyway to something a little snazzier. I've not owned a Samsung since the Galaxy S3 and I hated touchwiz back then, but the missus has a Galaxy S7 and it seems to have come along way, although i'd probably sit Nova over the top anyway. Going to the S8 would mean I would only be going down from 5.9 to 5.8 inch screen which is fine, as I dont want to go back down to 5 inch at all.
Will most likely be moving to EE from Three due to contract change, and would be making use of the Wifi Calling as some areas in the house are dodgy signal.
Umming and arr'ing art the moment but there seems to be little else to go for - I dont fancy the OP5 at all
