From my understanding, they stretch to fill 21:9. So you lose nothing but it looks funky as it's stretched.
You see LESS of the map/arena than on a 16:9 monitor.
http://www.pcgamer.com/overwatchs-new-219-support-actually-reduces-field-of-view/
I have tested it myself, what Misschief is saying is that the exact same FOV is used for 16:9 as 21:9 but then the image is cropped at the top and bottom to make it fit 21:9 without stretching it, exactly like cropping 4:3 video to 16:9. The easiest way to notice what's going on is to look at the weapon in that shot, the bottom of the weapon is cut off.I stand corrected about the stretching, however their screenshots look like you see more....horizontally looks identical but vertically for some reason there is a little more showing. Maybe it's just the positioning was not the same.
That was my first thought, for most of the heroes and maps there is not a super amount of verticality.If you're losing the top and the bottom, that's not a big loss. Seeing more of the sides, where the action is more likely to be, is a bigger advantage. Trying to be impartial, I would say they've done the right thing.
Just got this today. Have to say it's enjoyable right from the start and I know nothing. Can see where clever tactics could really make a difference. Impressed so far.
I got reported for inappropriate battletag cause I'm not great at widow.
Other People are the best part about multiplayer gaming.
What is your batteltag? Were you playing Quickplay or Competitive?
And mode shouldn't make a difference, but I've only ever played quick play.
I jumped on for the free weekend (I would have gone in on the previous free weekend, but I wasn't sure if my G1820 would be up to the task even with a GTX1050Ti bolted on which it can at really decent settings and can keep 60fps almost all of the time) and I'm now completely hooked enough to spend the £17 for the standard edition (I don't really need all the extras that come with the GotY edition since I don't play those games).
I decided to start off gently against AI enemies and I was just kicking face with D.Va (I also managed to get a 4 kill with a self destruct), but as a Mr Solo once said "going against remotes is one thing, going against the living is entirely different" and while my first (and only since there didn't deem to be that many people playing in quick play late at night) match in quick play mode went well, I didn't end up with a zero death match (I at least only got killed twice during the whole match).
