Caporegime
- 18 Oct 2002
Stick with what you've ordered, it'll last you years.
In that case new rig tonight
At the end of the day it's cost me £10 so I doubt I'll be complaining any time soon![]()
This new pc is amazing! GTA with everything maxed out looks incredible! Well chuffed![]()
The blanking plate at the back that is missing is because I haven't decided if I should put my ASUS XONAR DGX sound card back in or not.
Would the on-board sound on this mobo be better than the DGX anyways? Or should it put the sound card back in?
Thanks,
G
Deffo need a monitor upgrade with that rig... a 1080ti is overkill if you're staying at 1080p @ 60hz. Nice rig though dude
I have a Gigabyte Z170M Gaming 5 motherboard and the onboard sound with the additional software is a lot better than a DGX I tried in there. Onboard sound has come along way. I had to go to a Soundblaster Z to notice an upgrade on sound clarity.
Most people seem to notice a difference from 60hz to 75hz, however I've seen a few people state that they can't. Try it for yourself, let us know.
If you want your 1080ti to last for say 4 or 5 years playing games at max settings, keep the monitor you have now. Otherwise get a 4k 21:9 monitor and enjoy.
Also I wouldn't personally bother getting a new soundcard, unless you primarily use some decent headphones. Soundcard differences are minimal when using speakers IMO.
