With new hi spec monitors on the horizon and ever more demanding games being launched mGPU going forward is the only solution.
If some one wants to play the latest game on a 144htz 2160p monitor (when they are available) not even a top of the range Volta Titan will be able to do the job or even get anywhere close.
It depends on your preferences I guess. If you don't mind lowering a few settings and disabling AA for example then it's totally possible. Lets face it at 4K AA makes little difference and high-ultra on most games is also minuscule.
However yes, no card for the next gen or two will be able to max 4K 144hz with all the eye candy.
SLI is brilliant when it works but when started getting worse fps than a single card, that's when I got fed up and ditched it, I'd rather just tune a few settings.
