Typically the 4Gb versions of the cards have slightly lower memory clock speed. They also come with different timings on the memory which means you can't just overclock them to match the speed of the 8Gb cards as it loosens the timings from anything higher than stock, resulting in less performance and it's the memory speed that really makes the difference when mining.Does the mining require 8gb or is the cheaper 4gb versions of these cards fine, 3gb even for the 1060 I guess. I used to mine the scrypt coins a while back, the reason alt coins went up a lot is bitcoin is over flowing with transactions and cant handle all the business it needs to. Many then speculate alt coins will be taking over, Ether is possible overly favoured when work could also be done elsewhere.
There is also the nuclear option of not POW but POS which for those who do not know excludes miners, the work is done by deposit holders and does not require GPU at all. Its possible mining on pc becomes history by year end or sooner, not sure but roughly I know the POS wallets can handle all the work done (expensively) by GPU and bitcoin ASIC factories even.
Bitcoin transaction fee can be $85 or more which is stupidly worse then FIAT, POS networks will handle this under $1 and in a few minutes confirm it. Common sense says markets dont pay the ransom and will go low cost but I dont think it'll be simple transition
I Started my first bit of mning last night. Only using my main rig with a 1080. Set it running at 10pm and up at 6am and its made $2.50 with a prediction of $175 a month.Im starting to like this!
My RX 480 uses under 100 W when gaming at 99% usage. If the GPUs use roughly that amount of power whilst cryptomining and if they were running in a server which was on 24/7 anyway, you're looking at ~900 kWh per year per card, which at 12p/kWh would be ~£110.I take it you all get free electricity??
Get yourself a homemade wind turbine from an car alternator and a solar panel and run that puppy for free!My RX 480 uses under 100 W when gaming at 99% usage. If the GPUs use roughly that amount of power whilst cryptomining and if they were running in a server which was on 24/7 anyway, you're looking at ~900 kWh per year per card, which at 12p/kWh would be ~£110.
Talking of electricity prices, I'll be pretty depressed when my current plan ends in a few months. The best deals right now are nearly £100/year more than what I'm paying now!
If we had more details about Vega I could probably sell my RX 480, go without for a month, then not have to pay much more for Vega. As it stands though, I have no idea how good it'll be, what it'll cost, or when it's coming out. So...wow, makes me 1% guilty I have 2 XTR's that havent been powered on for two weeks haha . saw on a face book page someone got £290 for his Asus Dual 480 8GB within 15 mins ! insane
I still have an R9 270 but at 1440p it's pretty dire.personally would sell up and wait . heck ebay/MM for a £30 card to tie you over if needs be
