I think mine is raid (set up as mirroring).
Will the amber light still show till its done ?
Will I loose any of the data i backed up recently ?
Is it possible to cancel it and just backup what i currently have ?
What is R5 ?I'm predicting R5 with multi-TB drives. Cross your fingers
Ok i see it now raid1 (I must have been blind due to stress)It says RAID 1 - so at the moment you shouldn't have lost anything. What happens if you press F1 to attempt to retry recovery as per the boot screen?
Otherwise time to replace a disk. And make a backup...
Does it need to be the same make and model ?
I did, it had me really stresses, I could not figure out what the issue was and worrying about the other possibilities.Right. I misread the last image. In which case, the OP has instead learned a valuable lesson in why RAID 1 is a good idea.
Not really, though it's best. But it needs to be at least as large as the other drive. However, now may be the time to change both of them. Is the good drive readable outside of the array? If so, remove it, put in a new pair of drives as a new RAID 1 array and copy from the old disk onto the new array.
