Permabanned
 - 4 Sep 2011
 - Durham
Anyone know if you still get the UBI game with the Ti?
According to Nvidia site the promo has ended so no more codes will be going to suppliers and I cant see overclockers advertising free games with 1080 ti, so I would have thought codes are all gone. Speak to overclockers if you want to check but I think it unlikely.Anyone know if you still get the UBI game with the Ti?
So, anyone else found that voltage does nothing for OC?
Can manage 2037.5 (used to be 2050), and though voltage would help, but does nothing.
Not too worried about it, as happy with the performance I have. Just curious really
Got my super jetstream and replaced the old super jetstream!
Clocks a little higher than the 2ghz I got from the 1080 and settled around 2080ghz . I stuck 400 on the memory and its stable but Ive never really overclocked the memory on any cards Ive had so I dont know if I will leave that alone. Its a little underwhelming as its just the same card I had before but performance wise its on point. Very fast and very quiet.
Now to max some gamers on my X34 and admire all the graphicz I now have![]()
Getting above 2000 is classed as a lemon?
 I dunno.
Have hardly followed current gpus and and their ability. I just got the limited impression a decent one got closer to 2100
Am I very wrong then? Do many not get over 2k?
Yes you should be pleased with that. My STRIX OC starts at around 2012 but due to gaming at 4k it throttles back to 1987 after 20 minutesAh right. I'll not call it a lemon any more then![]()
.  Its not great but ive seen worse after gaming at 100% usage and temps getting as high as 73 degrees C
