- 13 Jul 2004
- Stanley Hotel, Colorado
Come on the average guy wouldn't be using LN2 for cooling.
They are extrapolating previous data to speculate on the missing Vega data. Presumed logic would be its not possible that Fury in any feasible extreme setup could outperform Vega at room temperature, so theres a baseline to work from
So is HBM2 smaller cheaper to make, must be some point missing. Chart below shows advantages are with 2nd gen ?The reference FuryX has 512GB of memory, the best case scenario for vega is the same 512GB/s, but more realistic given recent HBM2 rumours would be in the 410-480GB/s range.
https://www.extremetech.com/extreme...-huge-size-advantage-of-hbm-over-gddr5-memory
The highest amount of memory will be on the professional use cards.(logic being 16GB would likely be on the higher end gaming card)
https://www.digitaltrends.com/computing/nvidia-quadro-m6000-24gb/
