- 6 Mar 2017
- Sunny Bournemouth
They've come on a long way, looks so much nicer than my old model. How easy are they to clean? The older one can be a proper pig with plastic moulding patterns!
I have a DeLonghi Magnifica and have been using it for a couple of years. I drink only latte's and always find the milk frothing to be very variable. Obviously, my technique is probably at fault, but sometimes the milk is creamy just how I prefer it, and other times not so much.
]Well for one, Guernsey milk has a higher protein content, and its the protein content that creates the stable micro-foam. It's also got a higher natural fat content, which means the whole milk breaks the less-fat-is-more-foam curve. I steam whole raw guernsey milk every morning for my morning coffee, and i easily double it.
Taste-wise, its beyond comparison.
I found that to start with, but I'm getting it right most times now having practised a lot.
I took the auto frother off mine and my latte technique (copied from a Delonghi-specific YouTube video) is to blast out residual water, then put the tip () just below the surface of the milk, stretching it up for no more than 30 secs, then I move the tip up and down (
) until I can hear the sound change to almost a simmer.
Nice and creamy most times. Start with milk as cold as possible.
Do you use skimmed milk ?
I've used both the Delonghi one and others, didn't notice any difference at all.Do you guys use third party descalers or the delonghi official one for your magnificas?
Had mine for 5 years now i think, got it dirt cheap on factory seconds (knackered box basically)
I found a bottle of the stuff instead of the little packets so picked one of those up this time, i have always been worried about knackering it with third party descalers even though its probably the same chemicalsI've used both the Delonghi one and others, didn't notice any difference at all.
Not sure I want to post a vid of my fluffing techniqueOk. Someone needs to post a video of their frothing fluffing technique!
..and here's how it makes a shot:
They're Sumatra Mandheling from Waitrose. Best I've found in a supermarket so far.whose are the beans then ? they seem very darkly roasted with, unusually, quite a lot of glossy oil on the surface, which (post in espresso thread )
can mean they may have a better taste but shorter life span.
Used to buy Italian roasters 'BAR' roast like those, they also tend to leave a lot more residue on the grinder too.
I have my left dial set almost at the bottom, I hate the extra water being pushed through the ground to make a bigger coffee - I just add water from the kettle (temp controlled obv) and find I get a much better cup.
