No delivery yet, I guess Monday it is!
I really want to get the M3 boot liner carpet, but it's at least £50. I don't need it, just want it, hence not wanting to pay £50 for it![]()
I spot some overspray on the wheel! I'd have expected your steering wheel trim to be black, mine is the same colour as the top piece of trim, and my dash/door trims are the same colour as yours. Also, the lower steering trim comes off super easy, takes 10 minutes max.
After 2 years, my steering wheel is finally showing some signs of wear, notably on the lower right grip. I'll let it get a bit more obvious before contacting Royal Steering Wheels once more.
This is the mat I was looking at for the boot.
Well actually it didnt take long to mask off and do.
Also i looked into taking it off and you have to take the airbag out to remove the trim. If i removed the steering wheel you have to take the flappy padals off which ive heard is a pain to do and reattach. Even if i just remove the airbag that means disconnecting the battery, and taking the time and patience to remove the airbag. Then having to reset my android head unit up. So the time to do that and so on is probably longer than masking it off.
Secondly do you guys own an e46 and does it matter, it's done isnt it and no skin of your noses.
Do you need to own an E46 to have a view then? Seems an odd prerequisite to express an opinion on a discussion forum.
I don't have an E46 but I do have an E39 with exactly the same steering wheel. Doing it that way is madness, removing the airbag takes about the 3-4 minutes and from there the trim simply unscrews.
i have now updated the OP as it was hilariously out of date given everything that has been posted since. Makes photos and stuff much easier to find in such a long thread![]()
Eventuri was £500 with cutters discount when I got it, it's now £750!!
