- 1 Dec 2010
- Welling, London
Just googled it what happened today. Utter tools the lot of them.I assume Britain First.
indeed you're not - though if you do live in such a high rise and you're sufficiently worried you could stash a big climbing rope and couple of harnesses in your wardrobe just in case
Indeed.Just googled it what happened today. Utter tools the lot of them.
You're probably better off with fireproof suits and an oxygen tanks. Most tower blocks have very strong and concrete stairwell designed to be a safe haven from fire, so you'd be far better off getting through a few flights of hot, smoke filled stairs. If you can get though those floors and under the fire, you can get out. Although in this case, it seems like the fire spread absurdly fast, and I'll not be surprised if the investigation finds the cladding held the burning insulation to the building, helped the burning parts fall inside the building and kept it going that way. It was like one of those candles that have a wick around the outside instead of up the middle.
I don't think modern high rises have them...On every corner of should be a simple slide ladder down external fire escape, like every tall residential building in NewYork has. Safety cannot be disregarded because it's unsightly
Erm, no. If you saw the regulations we have to adhere to it'd really change your mind. This block was built before the regs wee put in place, hence the lack of fire systems. Our building for example has over 600 fire doors, pre-action systems, VESDA systems, main sprinkler system and a very comprehensive fire alarm system.
When I was in the states last I was amazed at how backwards they can be when it comes to life critical systems and procedures.
Id imagine a side ladder in this instance would have caused more deaths than saved. Imagine all the plonkers climbing UP IT when there isn't a fire.
NYC needed it though as almost all of the inner city is high-rise or medium-rise.
Our local community up north shy of Liverpool are getting together and collecting any spare clothes, bedding, none perishables, nappies etc. We have a guy traveling down Friday with all local donations. I really do love it when people come together and help each other out at the most needed times <3
