The inbreeding will sort that out over time
I think that's the cause.
They are apparently quite difficult to use, even by a stuntman in controlled circumstances and modest heights. It's easy to miss them, and they deflate to catch a body. If two people tried to use them at the same time, they would both die, even if they could fall and hit a relatively small target. Probably impossible from the top of a burning tower block.
Besides being potentially abused by drunks.. why don't high rise apartments have strong attachment points, and emergency rope/ carabiners, so occupants can abseil themselves down, perhaps one in each room or ones at communal areas?
People might say training needs to be involved, which is probably out of the question, however if you are at the point of abseiling out of your high rise apartment you are probably at last chance saloon and out of options. Learning to abseil, or just climb down the rope, on the fly probably has a higher chance of survival than jumping...
If you're going to think that far ahead, you'd be better off installing a proper fire suppression/sprinkler system. How are you going to the old, kids or disabled people safely down a rope? Do you know how big a rope you'd need to get down 20 floors?
Doesn't the smoke kill more people quicker than the actual fire. Masks wouldn't be a bad idea.
No, all that nonsense they put on the exterior of the building to make it look better seems was not fireproof, seems like the fire spread from one place vertically along the outside of the building, and then into various flats.
^^^ literally all anyone needs to say.
What buildings like this need are emergency fire proof elevators in the central core so that they're easily accessed by all.
yup - you'd need one that is 20 floors long plus about another 15 - 20ft on top of that to give you a bit of slack to work with tying it off to a decent anchor point
You have to question what all the cladding was for. It looks suspiciously like it was there to tidy the building up, rather than service any meaning benefit to the residence.
An old, outdated, unsafe building covered in a flammable party frock to keep some of the more well todo locals happy.
I didn't say how long, I said how big. It's physically large to support it's own weight, and you'd need a lot of them. They'd have to be checked and replaced regularly, and pretty sure you're not going to get randoms to abseil through flames. You might as well ask for a set of giant harpoons that would pin a wire down to the ground and allow people to zipline down to the ground. Still no way to get kids, the elderly or the disabled down. Instead of asking for silly movie stunt equipment, all that's really needed is a working sprinkler system, and not building them like inverted wicks.
Sorry, what does BF mean and is that supposed to be harassing?Except for the tools BF harnessing Muslims donating food.
I assume Britain First.Sorry, what does BF mean and is that supposed to be harassing?
I hope with the building being old it wasnt full of asbestos.
