The Alienware 17 Laptop Appreciation Thread
9 Aug 2004
Plymouth, UK
Took delivery of a 17 R4, i7-7700HQ, 16Gb RAM, GTX 1070, 256Gb M2 SSD, 1Tb HDD, 1440 AOU panel (no banding/striping so think it is most likely a Rev 1.4).
Was delivered 2 weeks ago but only just really got to play with it as been on holiday in Greece for last 10 days.
Absolutely love it so far...no issues whatsoever. Build quality is fantastic. Bit on the heavy side but not intending to take it very far. Gaming performance is excellent.
Purchased from the Dell outlet, originally paid £1478 (this was with a 15% discount code). Just negotiated a further 10% reduction using the tip mentioned above bringing price down to £1330...not too shabby!
9 Aug 2004
Plymouth, UK
I used HWINFO and confirmed it was the AUO panel...unfortunately it does not give the Rev number. However I am pretty sensitive to screen quality issues, can see no banding/striping on the panel whatsoever so assume it is not one of the original AUO panels and (most likely) the new Rev 1.4.
28 Jul 2003
+1 for the AW17 R4. Absolutely superb (but needs a repaste with liquid metal to keep temps down and noise to a whisper). Build quality is second to none. It's a wonderful piece of kit and a lovely keyboard
14 Sep 2010
Batley, Leeds
I'm in the market looking for a laptop. how often do the R4's appear on the outlet store?
Also what are the differences between the R3 and the R4?
10 Nov 2012
Hi guys and gals. Seriously tempted to get one of these from the outlet. Scratch and dent ones though...are these minor?
Also R3 and R4....what's the difference? If I have a budget of around £1400 is a 1070 doable? I'm looking on there at the moment and really don't know what to go for. Are they still the best pieces of kit for the price (build quality etc) are any of these gsync or is that not needed?
Sorry bit of a ramble.
17 Oct 2005
Southampton
Mine was scratch & dent - the mark on the side of the lid is a few mm.. took me running my fingernail over it to even find the mark.
R3 - 9xx series GPU
R4 - 10xx series GPU
Probably a few other tweaks too...
They're built like a tank - every bit as solid as Apple - no creaks or flexibility here. I have a 1440p GSYNC and it works beautifully in gaming. Fab on desktop too, but 95% of the time I'm using it to game. Some people occasionally moan that the TN screen isn't vibrant or has banding. Either I got lucky, or I'm not so picky, but the screen on mine seems OK.
Any faults with a laptop from the Outlet, you've got 14 days (I think..) to return it if you're not happy.
17 Oct 2005
Southampton
Are you sure about the GPU just being 9 series on the R3? It's just that I'm looking at an R3 now and it has a 1070.
In that case, I may be wrong. I was looking at a 17 R3 a while back and the best GPU was a GTX980. I waited until the R4 was released which appeared to offer a GTX1080 as more or less the only difference. Later, there was a minor KabyLake refresh, but mines a R4 with a SkyLake 6820HK and a GTX1080. All the gaming performance I need for a few years! :)
1 May 2007
Manchester. UK
also the outlet models come with a 1years next business day warranty. anything at all goes wrong then they'll come out to you (work, home, wherever you want) to sort it if it can't be done over the phone.
i never found the scratch or dent on mine!
for gaming get the gysnc screen, its awesome.
the outlet often do 10 or 15% off codes, you can also once you've received it say you're not sure on it and want to send it back, they have been known to offer a further 10% for you to keep it.
price wise 1400 should bag you a 1070, i got a 6820hk with 1080gtx for 1640.
10 Nov 2012
Yeah definitely. I'll be happy with a 1070 for a few years. 1080 is a beast though.
10 Nov 2012
I've just seen similar on the outlet and I'd love it but it's over £1700. No codes available at the moment and part of me is wondering if it's worth that anyway without a discount.
