8Pack approved AMD Ryzen [email protected], 1800X performance smashing bundle :-)
20 Jan 2017
Cumbria
End of the month for the Dark Pro 8Pack SKU. 2x8gb 3200mhz 14-14-14 B Die Samsung IC special SPD.
Do you have a date for ETA Just I seen this so just I have them on order with other items and told sale to hold the other items on the assumption of this quote below
Trident Z maybe end of next week, first 8 Pack (3200MHz) also next week, 8 pack Xtreem end of month or July.
13 Mar 2007
South Yorkshire
Do you still get the stock cooler boxed if you buy either bundle?
I wouldn't be using it once installed but would be useful for testing before breaking my loop down to fit it all.
EDIT: Spoke to CS and they confirmed it does come with stock cooler.
3 Aug 2017
Hi
I brought this bundle but seem to be having problems loading your profiles.
I've downloaded them to a usb drive and its is FAT32.
If I try loading the Bios file I get "this is not a proper bios file".
IF I try loading the profiles I get "failed to load".
any help would be awesome thank you.
OcUK Staff
OP
20 Feb 2012
John Smiths Stadium
Try to download the latest bios from the abuse site and then use oc profile. Ezflash 3 is the utility you need under tools in bios. Navigate to your USB drive with the Bios file on and away you go. Once flashed u can use the oc profile again under tools section oc profiles.
