This is the heatsink from Vega FE, its just as unimpressive as the reference Nvidia cooler. Aftermarket Air cooling should easily work better.
full teardown here.
Is this the Vega thread or a scene from BF1. Way too much hostility over some silicon![]()
Whatever it is if we are going to go off the PcPer results and assume those are final gaming performance -10% or so it nothing like enough, that would make it 10% faster than my 1070.
Is this a $250 and 280 watts, thats not good enough, not by a very very long way, unless its really cheap to give the $250 crowed and upgrade path.
Its a Fury-X + 15%, thats shocking and with the cost to AMD of the thing surley AMD couldn't actually afford to make it and put it on the market? that would cost as much as they could sell it for.
So to summarise where we think we're at:
Or at least that's the hope.
- AMD focused on Vega's compute performance first and foremost. They have been vocal about attacking the strategic cloud/deep-learning sector and have invested a lot in ROCm and technologies (HBCC, SSG, HBM) that mostly make sense there.
- This is reflected in their driver work, where the 'compute' part is ready, hence Vega FE. AMD thought it's ok to launch the FE because it's not a 'gaming card'. As a prosumer card, as long as compute is ok, the gaming speed is not the end-all-be-all.
- Thus AMD just certified the very-first stable drivers and bundled them for the launch. Hence Vega FE sucks in gaming.
- RX Vega will launch with 'proper' gaming drivers and we'll see its true potential.
- Vega FE users will get a nice gaming performance bump when those drivers are released.
It will be interesting to see if some of the performance dips are down to the GPU hitting thermal and power limits too. If the GPU is kept cooler it should help drop power consumption AFAIK.
BTW,GN also said their estimate of the die size is around 526MM2(instead of the 564MM2 from PCPER),but AMD mentioned it would be slightly under 500MM2.
I'm not assuming that's all the RX Vega will manage, As I said it should be good for another 10% and hopefully a bit better if it's under water, But even with that it's not great because of how inconsistent it is, I had been hoping new things such as whatever it is that lowers the overhead would have made it more consistent across a larger range of games because that's where GCN has been letting itself down. But it doesn't seem to be the case from what the Frontier's shown and as stated AMD have said the current FE driver has all the latest optimisations already. And I can't see there being some miraculous improvement over the next 30 day's that they wouldn't have already done in the last 6 months.
We haven't seen any benchmarks of the released Vega doing compute workloads. Best we've seen is it is really bad at mining,
Maybe, be that as it may its nothing like good enough for a 500mm 280 watt GPU with HBM 2, its a $250 card at best and i doubt AMD would get good enough margins on that to put it into production.
Its another Fury-X + a little more two years after the Fury-X was already an under-performing card.
Its a high power consumption 1070, that's where PCPer resulted its performance... it has no place unless its very cheap. VERY cheap.
Not caught up with the thread yet... but have to post here. Didn't AMD say "zero to 8 percent higher"... not "much higher" perf?They were also told the gaming performance on the RX version of the card would be much higher, again PcPer ignored that and reviewed the FE card as if its a gaming card at its final gaming performance.
It was the PCper guy who said he thought there would be from zero up to an 8 to 10 percent increase in performance for the RX release, game dependant.Not caught up with the thread yet... but have to post here. Didn't AMD say "zero to 8 percent higher"... not "much higher" perf?
Where are people (not just yourself) getting this "much higher perf with RX Vega" from? AMD didn't say that, did they?
This is probably answered by the time I catch up to the end of the thread tho, knowing my luck![]()
That is why i gave up and started drinking GnT's
I for one welcome our magnet drinking robotic overlords.no love for a simple magnets with ice?
I'm getting flashbacks of the 480 thread now...........You made that up... i did no such thing.
no idea WHAT you're talking about...clearly I said magners
p.s ignore the sign saying I edited the post, it was our magnet overlords.
