- 28 Sep 2014
- Scotland
Well I've had to downgrade anyway with these drivers as WatchDogs 2 doesn't launch.
It seemed the driver was not caused Watchdog 2 to crashed from launch, a guy found Ansel was caused it to crashed from launch, he posted workaround to get Watchdog 2 worked with driver 384.76 on Ubisoft forum:
FIXED
The crash is caused by the NVIDA Ansel
C:\Program Files\NVIDIA Corporation\Ansel\Tools
RUN NvCameraConfiguration then disable
The game will then run with the new update
http://forums.ubi.com/showthread.ph...at-startup?p=12744658&viewfull=1#post12744658
Nvidia should have hotfix next week with Ansel update.
