Snip
I have found the Smok coils to be really hit and miss even with proper treatment and within the same pack! - have soaked them overnight and still had burning! I have been using my V8 Baby primarily with Q2 0.4ohm coils for about 2 months now and sometimes a coil is excellent and sometimes you put one in and you just get a burnt flavour.. not as bad as when a coil goes but noticeable in the vape.
I swapped onto the Smok tank as my Cleito Aspire's glass cracked but I got a couple of replacements today and moved back to that and the difference is noticeable.. get a really good Smok coil and its a better vape but the cleito is much more consistent in my book. The Cletio in my book also lets you use a wider range of juice I have found the Smok coils more likely to burn juice even on lowest recommended wattage.
In terms of juice if your like the Swamp Thang (one of my favourites also!) then I would also recommend you try some of the following:
- All the ruthless juices are good but I also really like Grape Drink and Rise.
- Furiosa Ice Beam is a great fruity vape with a menthol hit at the end
- VML - Mojito Lemonade especially
