Caporegime
- 18 Oct 2002
Fair enough, was a flaky rumour then
Is there even a remote chance this could land before the end of 2017?
TSMC's 12nm variants have only just entered risk production so unlikely to see anything before December at the earliest.
March - May being more logical options.
Dunno they seem to be putting a lot of effort into getting 10nm ramped up for Apple though that would likely mean nVidia wouldn't really get a look in until early next year but the "12nm" capabilities are also getting ramped up pretty quickly as well.
NVIDIA's Future MCM GPU Design Detailed - 256 SMs With Over 16000 Cores, Multiple TeraBytes of Bandwidth
https://www.overclock3d.net/news/gp...-chip_gpu_modules_to_scale_past_moore_s_law/1
So basically they try to make something similar to infinity fabric for 2021+
That leaves 4+ years (from the end of this month) to AMD mopping the market for good and without serious competition there......
Probably there'll be more cards in between Volta and an MCM design, too big a gap otherwise.
Well not if the design in the paper is close to final.
Although Nvidia are in a bit of a weird cadence since they've decided to go for Volta on 12nm. I can only assume there'll be some kind of 7nm refresh for Volta, unless they skip 7nm and go straight to 7nm+ in 2019/2020.
Point is, if they're going for ~4000 cores per module, and 3+ TB/s memory bandwidth, this means doing it on 7nm/7nm+ and with HBM3. This would mean 2021 at the very latest, which perhaps leaves enough room for 1 more architecture inbetween Volta and this MCM arch.
If they waited longer it would be on 5nm, in which case they'd be looking at considerably more than ~4000 per module and ~16,000 overall. Be more like ~25,000 overall bare minimum, and then they'd likely need something faster than HBM3 or need to redesign the layout to have 3 or 4 stacks per module, which then mean they may want more/less than 4 modules.
Basically if they waited till 5nm, it would completely change the design, whereas 7nm aligns perfectly with what they've outlined.
Remember in all of this the 7nm node is like a 1.5 generation jump rather than the normal 1, so we should expect to see the largest cards have 6000 cores minimum, and could easily have 8000+ (even 490mm2 on 7nm should be over 8000 cores).
Yeah there's a thread discussing that.
Upshot of it is, the earliest they could make that (both cheaply/small and meeting their memory bandwidth guideline) would be 7nm+ and HBM3 in late 2019/early 2020.
So this could be the successor to Volta, as that timeline would align. Or it could be further off if it was mainly for research purposes and they're not ready to do it yet (for instance they were intending on using the other stacked DRAM type which failed, not HBM, so they may need to redesign some things to accept HBM instead).
Refresh my memory please; why did Nvidia go with 12nm for Volta/
Well laid-out post, nice! The time line and node shrink surely fits so the question remains how hypothetical are the contents of that paper right now (like you suggested before me)? If the MCM arch can be Volta's grandkids that's be fantastic for computing in all its facets (from DP to Quadro cards to GeForce products) - CPUs will become the problem then...way to slow to keep up the big bang performance in crease of such GPUs I estimate. I'm still in awe by reading ~16.000 cores...
Refresh my memory please; why did Nvidia go with 12nm for Volta?
Volta was primarily designed with Summit as a major development focus which required a certain minimum performance/density/power target (due to being used in huge installations) which wasn't possible on 16nm and it was looking like 10nm wasn't going to be ready in time for nVidia to fulfil contracts using it. (By all reports the costs for 10nm and 7nm are astronomically more than those based off 20nm planar technologies as well so probably some cost saving aspects to it).
I'm actually getting kind of interested in what we will see when manufacturing in this area of technology moves wholesale to 10nm or below - a lot of DRAM, partly because it can be complex stuff to produce, is still using bigger nodes or approaches that are still hanging onto techniques for bigger than 20nm manufacturing.
