Deleted member 138126
D
Hopefully better battery life as well?
Battery life hasn't been an issue so far, I had it nearly a month and it spent more time being used than charged. I think I only charged it one or two times.Hopefully better battery life as well?
There's not a lot of wiggle room with 128GB. 128GB drives are a *lot* slower than bigger drives, so you pay a price on that. And finally, the drive isn't upgradeable, so you're stuck with that size forever, which may be a big problem for you down the line.
It was from a review (can't remember which one, possibly the Are Technica one). For the 128GB SSD from the MBP 13 you'll have to wait until someone reviews one, and then you compare with existing reviews for either the 2016 models, or the 2017 with 256 or 512GB.rotor, where can I see the figures for the speed difference in the SSD's? I am contemplating getting the 128gb and I know there is discussion back and forth about space but that really isn't a problem for me as I have a NAS that I can access both in and out of the home, as well as a portable external drive.
However I'd like to know the sheer performance drop off between the 128 and the 256.
Anyone else finding theirs randomly freezes? Seems to be happening 3-5 times a week at the moment, cursor still moves but everything else stops requiring a restart
Well I have a slot on Wednesday to take my Macbook Pro in for them to look at/repair the keyboard.
Right side of the space bar doesn't register half the time and the volume up button requires a very hard press to get it to respond. Time to finish what I need doing website wise and back everything up ahh
Just got a refund on mine as the back light blew last night :/ Apple couldn't replace it in store as the spec was custom.
I'm also interested...What are you going to get instead?
