Poll: ** The AMD VEGA Thread **
On or off the hype train?
  • (off) Train has derailed
    Votes: 207 39.2%
  • (on) Overcrowding, standing room only
    Votes: 100 18.9%
  • (never ever got on) Chinese escalator
    Votes: 221 41.9%
  • Total voters
    528
Status
Not open for further replies.
The leak shows Vega in between 1080 stock and 1080 ti stock.
3dmark 11 Graphics scores.
1080 = 30030
Rx Vega = 31873
1080ti = 33961
They do have OC scores for the 1080/ti but we don't know if Vega can oc further as well. I wouldn't read much in to this either tbh as it's a pretty old bench and you can see that the gap between 1080 and ti is only around 13%
That result doesn't look bad to me, It was never going to be faster than the 1080ti or Titan X regardless of how much we wanted it too. Like you said RX vega's overclocking ability is going to make it or break it with regards to the 1080.
All AMD need to continue to do is release competitive GPUs
Yes but that's all any company needs to do (release a competitive product).
Unfortunately that hasn't happened for some time now with AMD and vega release certainly won't change that. A product launched toward the end of its competitors lifecycle that can't fully compete with the outgoing product let alone be destroyed by Volta, a product that is power inefficient, hot and noisy and being launched into a market where AMD's traditional budget strategy won't work is essentially..... a dead duck.
Ignore nvidia for God sake.
Vega doesn't need anything from nvidia AMD fans or people just looking for better bang for buck monitor plus GPU will be watching Vega.
So what if Nvidia has had this performance for over a year it means nothing to me and am sure I not alone.
You're not.
All nvidia care about is ripping of their highend market with GPU after GPU Ti ripping into the TX for example. It's a joke and only the die hard nvidia fans on here defend this practice.
I've never really cared about which brand of GPU I use but I've leaned towards AMD in recent years because the thought of them going under and leaving Nvidia with no competition is scary, Look at Intel for reason's why one brand is bad. Regardless of that Nvidia's behaviour since AMD announced that they weren't releasing a high end 400 series gpu has been disgusting, From the Founder edition tax & general pricing to the way they released the Txp, Ti & TxP almost on top of each other, The way they've taken advantage of us the customers is glaringly obvious.
Almost £500 for a 1070... are you mad? :p
Heartbreaking.
It certainly is.
AMD seem to be going backwards in terms of IPC from Fiji to Vega! And the power consumption of 300-375 watts for 1080 perf is INSANE!
who in their right mind is buying Vega, when it's 12+ months late to the party, hugely power hungry, and may not even be much cheaper?
You can't look at tests where you purposely throttle a chip to compare IPC's because that chip isn't designed to run with those types of clocks, I said the same thing about all those wanting to see Ryzen compared to Kaby lake at 4ghz, What's the point? It's irrelevant as no-ones going to run Vega at 1050mhz and Fiji can never get close to 1600mhz, Even if Vega does have a similar IPC to Fiji, does that matter? I don't think so, We're told NCU is replacing GCN and the first gen NCU matches the IPS of the top end GCN cards, That sounds like good news to me, The only way is up.
Brand loyalty and blindly buying only AMD or only nV is a fool's game. Forget "ecosystems"... buy the best tech on the market, that meets your needs. Ignoring one side of the other because you don't like them is extremely silly.
+1,
I get it in relation to going with Gsync because of the hefty premium it add's but not Freesync, I'd say that buying a non adaptive-sync monitor in order to avoid entering an eco-system is stupid. Part of why I bought a Freesync panel is because it doesn't hold the sort of premium that going with G-sync does, An extra 20 or 30 quid isn't going to break the bank but it is going to make gaming better when I do have a Radeon gpu to use with it and it'll help it sell quicker on the secondhand market when I finally upgrade to a new monitor again.
Am surprised people are willing to accept 1080 performance so long after release but I guess the Freesync force is strong. I do think AMD are going to struggle for at least another year or two to outpace Nvidia. I miss the 9700/9800 glory days.
Freesync user's have been stuck with best performance levels from Fiji, Which are below the 980ti & 1070, As noted when the 1080 and 1070 released Nvidia purposely made it so the 1070 overclocked could not match a 1080 due to how many bought 970's and overclocked them to stock 980 performance (I remember the topic being discussed by someone like Tom wotsit and Pcper). Although the 1080 has been out for quite a while AMD haven't had that level of performance, And that performance is ideal for 1440p & uw1440 so I'll happily live with that if it's sensibly priced.
The top cards are usually CPU limited at 1920x1080, and the 3DMark 11 performance test shown in the Wccf article runs in 1280x720 ofc its cpu limited.
This^^^
These days 3DMark11 is next to useless for testing as modern GPUs are just too fast and the CPU is a real bottleneck.
It is not even very good for CPUs as it can not use all 10 cores on a 6950X for example where as more modern benches like Time Spy can.
From this I'd assume:
Compute: MI25 and Firepro
Ultra-enthusiast: FE-Vega (watercooled version counts as the 'upgraded' version, so still fits the $1000 range kind of)
Enthusiast & mid-range: RX Vega. This would then lead me to believe RX may be $300-450, or $350-500 for full-die and cut-down.
I think Vega is more high end workstation/compute. Judging by what another forumer speculated on; its more a card for testing code that is intended to be run on the MI25
It's worth pointing out, it isn't GTX1080 performance, it's AIB GTX1080 performance, this means AIB Vega will be nipping at the heels of the GTX1080ti, depending on price that's very attractive.
At stock maybe but let's face it vega won't overclock and if by some miracle it does it will rule out anyone with less than a 1000w psu!
So because Vega and Polaris didn't clock well, it means Vega won't either just because? I am not sure how well it'll clock but I'm not ruling the possibility out completely. Plus with their tile based rendering method properly working it should use less power too.
79xx release, 290 release, fury release, vega release? Will anything be different from the previous high end gaming cards? I hope so.
The only release lately that has been a roaring success imo was the 480, but not that many wanted a mid range card at the time and if it wasn't for mining i think the 580 price would be reasonable.
I know one thing, with hbm2 there not going to be cheap.
The 79XX cards were fantastic, and the 290/390 cards were great too. Even Fury is by no means a bad card at all.
Yeah, my Fury Pro on my XL2730Z was as smooth as silk and still is. I am currently running an EVGA 1070 (Given to me by a friend) and in all fairness it runs cooler, however I would still prefer the smoothness of the Fury on Freesync rather than a higher FPS score. it's all bout the smoothness of the game due to the fact that cards in that bracket at 1440P will all give you well over 60Hz anyway.
:D
The olden days had both NVidia and AMD cards overclocking well. NVidia released GPU boost, which kind of kills overclocking worth and even my 1080Ti will give me another 100Mhz over the stock 1950Mhz but the returns are so minimal, it really isn't worth it. AMD needed to respond, so they had to up their clocks to a point where overclocking was very limited and looking at the big picture, if those wccftech benches are to be believed, AMD will want to be ahead of the 1080 in most of the bench results and for this reason, I doubt that there will be much room for overclocking. Using the FEs power usage as a guide, it is already using huge amounts of power at 1600Mhz, so again, I doubt very much that there will be much headroom for overclocks.
That apparent leaked RX Vega score is no different to what can be achieved with Vega FE, Define the guy who first benchmarked one got scores around that when he managed to stabalise the clocks to 1600MHz. All of his scores are on Videocards.
which makes me thinks its just a Vega FE thats not being recognised properly.
Status
