Got an hour out of OCCT linpack avx and 1000%+ from memtest and still constant F9 error bootloops.
Annoying.
Weird, my 1700 @3.85 on an msi b350 tomahawk arctic has been running for a few months now at DDR3333 tight timings. I have 3600 rated g.skill ram though, samsung B die. My cooling is decent enough though, got a 240 AIO on there. I think my vcores about 1.36 and soc voltage is about 1.1. I think the ram volts are at rated 1.35v. I can get it to boot and both 3466 and 3600 but havent managed to get it stable at those speeds yet. Its plenty fast enough at 3333 though, I think the timings are like 14,14,14,28 1t off the top of my head.
Matt
Annoying.
Apparently X299 is suitable for summer season, free barbecue grill.So tempted to ditch my 4770K due to board issues. What combo do people recommend?
My one is coming today, so excited new shiny things. Last pc update ages ago 2009.My 1600 has been shipped and will be with me on Sunday after I return to the UK. Looking forward to the build and overclocking attempts![]()
I’m on micro atx. I was eyeing the 1700x/16 or 32gb RAM/good ASUS board. Will be used for gaming/vr.What's your budget?
Ryzen 1600 for 6 core and Ryzen 1700 for 8 core are the best bargains.
If you are a high end gamer or you use the system for video editing, id probably go with 8 cores for future proofing.
Yeah I will be testing more, but that's going to be 99% stable or whatever which can't be enough for it to keep failing to boot consistently.
Ok, 2000% stable overnight and still bootlooping with an F9 error code. Very frequent at 3333 (as tested) and less so at 3200 (untested but nothing else changed).
I think it's struggling with periodically deciding it wants to retrain the RAM or something.
It's g skill 3600c17 stuff which I understand is B-die.
Have you checked to see if it is actually B-die to actually rule out it being due to a difference IC?
I will though!Read that wrong...
Have you tried adjusting CPU_SOC and the CLO VDDP rails? That may help.
If you are getting Q-Code: F9 all the time on a boot then an aspect like:-
- RAM MHz
- RAM Timings
- RAM voltage
- SOC voltage
- ProcODT
May need tweaking. CLDO_VDDP resolves memory holes. Increasing it does not always help, sometimes decreasing it does. It's not like usual voltages where increases help "issue".
