Indeed!So..about this Threadripper/SKL-X...
Despite being overkill for my needs, Threadripper seems like a tempting upgrade path for my flaky X99 system. Just really waiting on launch reviews and pricing at the end of the month before deciding. It's probably been mentioned earlier in the thread but FYI for those considering Threadripper; the TR4/SP3 socket it uses is massive so you will most likely need a new cooler if you don't opt for the stock one. Noctua for example have already said "...Since the heatspreaders of the new SP3/TR4 CPUs are almost twice as big as the bases of Noctua’s normal CPU coolers, it is not possible to use them on these sockets and there will be no upgrade kits."
