Only 10 core Skylake, 18 core must be gigantic.
10 core might be the same package with some cores disabled - though that usually bodes well for overclocking if it is the case - which hasn't really happened :s
I understand Threadripper is 2 modules but it is still only a single die if you know what I mean. What I'm trying to say is how will the thermals behave? Will it be twice the temperature of a R7 or will it be less due to the large surface area of the ihs?
Ryzen was pretty good on thermals I'm just wondering what to expect with threadripper. We really don't want a repeat of skylake x, so hopefully with Threadripper, it having a larger surface area will help negate the heat generated by 2x R7 modules, that and the fact that it is soldered.
Hopefully that made sense![]()
I was talking in a pure weight/looks point of view.
Temps are generally better under the D15 but its fugly as hell.
Considering the heat of the 8 and 10 cores; and people not even doing overclocking stability tests with with AVX active; I'm not sure how well their 12-18 cores are going to run. Either clocks are very low, or temps are going to be ungodly.
It's not a single die. Threadripper is two dies, each die is 8 cores, with 2 core-complexes.
Just like that photo of Epyc shows 4 dies, for 32 cores.
Temps should hopefully be good, as the supposed leaks show similar clocks as the R7's; overclocking might be a tad limited though.
Silicon lottery are binning the x299's with minus avx offsets. And are coating the VRM's in liquid tape. Not nice.
Sorry just my poor wording. It's one chip in one socket with one cooler is what I'm getting at.
When can we realistically expect threadripper prices/reviews/availability?
26th of August 14pm CET, source WCtech
Actually is 2 chips on a single socket, with a huge gap (relative speaking) between the chips. Making them easier to cool.
Look at this. This is the 32 core EPYC. The Ryzen 9s are 2 of these on each side of the PCB
That design is very easy to cool efficiently, because not everything is build up to a single die but 2, and the surface area is pretty big.
It will be similar to cooling 2 CPUs.
On contrary with the Skylake-X everything is packed tight in a single die which is smaller than two of those dies also, making it difficult to cool efficiently.
(7900X on the photo)
No idea, but I just ordered 32GB of G.Skill 4266Mhz sticks; so 2 pairs of 16GB. They work well in Ryzen, and Skylake X and were on sale at a steal. So which ever platform I go with I should be sorted.
Just need my Treadripper info and reviews!![]()
Hmm, you are gambling there for both platforms.
Two pairs of RAM kits doesn't mean they are guarantee to be quad channel compatible if all put together. There might be, but might be not also. Not guarantees there.
Is advisable to pick quad channel kit. Also we do not know the supported RAM on the X399, and what ram each mobo manufacturer would support.
eg the GA X99 gaming I have supports my 3600CL16 dual kit, but the Asus boards do not. (hence picked gigabyte)
However every Z170 and Z270 board supports that same kit.
Im hoping that AMD will give INTEL a run for their money again and spark the red, blue war again.
