(don't live in the outback and only 300-400 metres from fibre enabled exchange)
It may be the case that you are directly connected to the exchange and the exchange needs to be upgraded.
The BT checker is more accurate, so it looks like you'll be waiting. Bummer.The first link gives me Stoneycroft exchange cabinet 54 (ADSL only) but the second link says cabinet p38 (FTTC). I don''t think I am going to really know until I get in there and have an actual line installed. Checking the BT openreach website I get this:
The solution for exchange only lines is to install a new cabinet along the route or reroute the telephone lines to an existing cabinet. Apparently installing the hardware inside the exchange drowns out the ADSL frequencies.It may be the case that you are directly connected to the exchange and the exchange needs to be upgraded.
Funnily enough years ago we use to use T-mobiles unlimited dongles and the HSPA+ or whatever it was use to give us better speeds then we get now through our copper ADSL.
Unfortunately no one offers unlimited data since 4g has been introduced, at least nothing you can use for anything other than a phone, would never of even bothered with a landline if it still existed
EDIT: we get 8mb max on our ADSL line
At that distance I would've thought you would get higher speeds, I was getting 5mb on a 3km line. Is this normal ADSL? Not even ADSL2+?
I'm on 22mb with 3dB snr on the downstream Not sure it's worth upgrading to fibre yet as my nearest green box is 321 metres away.
https://www.dslchecker.bt.com/ will give you an estimate.
.In a small village called Scholes in Leeds. We are all stuck on between 2MB - 5MB with no future in sight for anything faster. Just to be clear, thats the speed of "Fibre" in this area as both our cabinet and exchange are absolutely miles away. Working from home makes this even harder to stomach. Keeping my fingers crossed that Virgin cable up around here soon enough. I think theres over 200 registrations on their site currently and we are right next to a cabled area.
If you have 17Mbps on ADSL you can probably see the exchange.
