- 18 May 2010
- London
which GTX 1080ti models should I be looking at when shopping?
I rarely OC any of my devices anymore with my failed 4670k overclock (stability issues).
I have a 4670k no OC, 8GB RAM, 1TB SSD, Z87 mobo.. do i need to upgrade before I smash in a 1080ti?
I'm hoping to play old games in 4k 60fps (basically from dark souls 1 all the way to dark souls 3).
In my experience with overclocking the most trust worthy way I have found to test the CPU stability is 8 hrs of prime 95 small fft with error check and rounding turned on.
If your CPU can do that, then your 99.9% close to stability. And should be good.
Just find your max safe voltage and max safe temps and stay below those.
Job done.
