Getting a few cases now where EGR valves are failing shortly after the update.
Snip
Will keep avoiding the update for the wife's car then, doesn't sound great.
Another reason not to do it, leaked documents from VW show the fix has had little or no real world difference in emissions.
Because the test is still meant to be linked even if it doesn't represent real world. Hence when they were found to have zero coalition thanks to device they were found to be cheating. You would expect a reduction in a test to have a reduction in real world, even if the figures are totally different.Why would it?
Not really, no. Given the way the cheat worked to detect being in laboratory conditions, and changing the engine mapping to suit, the only way the "fix" could make a difference is during the same conditions whereby previously the "cheat" would have been active. Real world engine mapping and performance was never in question, so likely hasn't been drastically changed.Because the test is still meant to be linked even if it doesn't represent real world. Hence when they were found to have zero coalition thanks to device they were found to be cheating. You would expect a reduction in a test to have a reduction in real world, even if the figures are totally different.
so the government (post brexit?) just need to modify road tax accordingly ?eg BMW 1 Series Diesel 2016 2.0 150 2 Manual Euro 6 D - euro 6 car with pollution at level D euro 4 level.
Through work I was at a meeting with engineers from Wolfsburg on June 1, and very obviously the conversation came around to this topic.
Apparently the way that the fix reduces NOx means increasing soot, no way around it, that in turn then has to be burnt off in the DPF and to do that requires additional fueling, to burn off the additional soot produced.
To do this the software changes the injection pattern, so fuel is now pre-injected, followed by a main injection, followed by a 2nd main injection..
Problems have arisen when injectors were old, dirty or worn and where the EGR valve stem was worn, because the whole emmisions system is now working so much harder to provide extra fueling and burn off the extra soot.
So to deal with that extra fueling and soot and particulates, parts that otherwise were working well below their rated capacity are now working far nearer their rated capacity, none of the failed items returned to Wolfsburg and analysed, have been found to have been working over rated capacity as yet.
That is why as Orionaut said, VW are saying there is no direct relation between the software fix and part failures, because problems that would have occurred anyway eventually, are now occurring earlier, as the system is working harder.
Vehicle Excise Duty beyond the first year is not based on CO2 emissions anymore
real world figures - The EQUA air quality /Nox charts here make interesting reading showing the(EQUA air organisation) real world emissions compared to what their Euro classification is
