Another issue about how convoluted the whole benchmarking websites/youtubers is in relation with the 7700K and why it performs so much better enjoying it's high clocks than the Ryzen or SkylakeX, is obvious on the video bellow. Look closely at the core by core load between Nvidia and AMD. Same fps between Vega & 1080 (irrelevant to this thread), and same 100% utilization,
 but focus on how differently the CPU core loads act.
(this is the first ever benchmark run using AMD card against 1080 in such video).
The games usage with the AMD card, spread more evenly across the cores compared to Nvidia one, which clogs one thread at 90%+ some times.
Also observe the overall CPU usage on the NV cards is almost double that of the AMD cards. Still FPS and detail is the same.
And no, I am not "pro AMD Ryzen" or "pro Vega". It shows why SkylakeX and Ryzen perform so poorly against the 7700K on all benchmarks up to now, were common denominator is the GTX1080/1080Ti. (aka NV drivers).
The 7820X shouldn't perform poorly against the 7700K as benchmarks show. On the contrary at 4.5Ghz should be crushing it and the Ryzen 7 or the 5960X/6900K also, let alone the Ryzen 5.
Same applies to the 7900X which is great CPU, even if very overpriced.
