The AMD Driver Thread
Happy to report, since BIOS update this is the longest the PC has gone without crashing. Looks promising :D
Good news, also bit of feedback on the 300mhz core clock issue you had, if you have afterburner installed, completely uninstall it, don't save settings. Restart your pc, then install it again, however do not unlock overclocking, just been having a mess around with my card and had the same thing.
No afterburner or anything like that. Completely clean install of windows, only latest AMD drivers. Everything is on default in the drivers also. Won't touch anything for a couple of weeks until I know the card is fine :)
Installed the new Vega driver for my RX 480 this morning, everything working fine so far, and my memory clock goes down to 300Mhz now when i switch off my DP monitor while leaving my 2 Samsungs on, this didnt happen with the 17.7.2 drivers, memory clock stayed at 1750Mhz.
MSI Afterburner 4.3.0 seems happy with these Beta's too.
Are there any advantages in the latest driver compared to the previous ones?
I saw they were bringing more Relive or sensor display options but no idea in already or not.
ReLive looks like the same updates found in 17.7.2, Enhanced Sync in there so Vega gets this along with 400/500 series. No extra perf in 3DMark or Heaven and Valley, i ran those earlier.
17.8.1 Drivers just released today
http://www.guru3d.com/files-details/amd-radeon-software-crimson-relive-17-8-1-driver-download.html
Radeon Software Crimson ReLive Edition 17.8.1 Highlights
Support For
  • Radeon RX Vega Series Graphics
  • Quake™ Champions Early Access
  • Agents of Mayhem
Fixed Issues
  • Some protected content applications may experience an HDCP error code while playing Blu-ray content.
  • A limited number of HDR enabled TV's may experience intermittent HDMI signal loss.
  • Grand Theft Auto V may experience an intermittent application crash.
  • With Enhanced Sync enabled Video playback on desktop or YouTube playback in Google Chrome may cause tearing choppy playback.
  • Forza Horizon 3 may experience long or extended load times.
  • FreeSync displays may experience stuttering when watching fullscreen video content.
  • FreeSync brightness or flickering issues have been resolved on a small amount of Samsung FreeSync enabled displays that may have been experiencing issues.
  • Tekken™ 7 may experience a crash (Chapter 13) on some Radeon RX 380 Series graphics products.
Known Issues
  • GPU Scaling may fail to work on some DirectX®11 applications.
  • Radeon WattMan may not reach applied overclock states on Radeon RX Vega series graphics products or may cause mouse stuttering when left running in the background.
  • Windows Media Player may experience an application hang during video playback if Radeon ReLive is actively recording desktop.
  • Secondary displays may show corruption or green screen when the display/system enters sleep or hibernate with content playing.
  • Unable to create Eyefinity configurations through the Eyefinity Advanced Setup option.
  • The "Reset" option in Radeon Settings Gaming tab may enable the "HBCC Memory Segment" feature instead of setting it to the default disabled state.
  • After resuming from sleep and playing back video content the system may become unresponsive on Radeon RX Vega series graphics products.
  • Bezel compensation in mixed mode Eyefinity cannot be applied.
Package Contents
The Radeon Software Crimson ReLive Edition 17.8.1 installation package contains the following:
  • Radeon Software Crimson ReLive Edition 17.8.1 Driver Version 17.30.1051 (Windows Driver Store Version 22.19.666.1)
This is awesome news for CF791 owners!
Now, should I buy one when I hopefully get my Vega on or around the 28th if OcUK comes through for me?
Support For
  • Agents of Mayhem
Fixed Issues
Known Issues
Package Contents
Don't forget about this....
I recall the uproar when an icon was installed, be interesting to see what this brings :p
(off by default, but still....why not just give an option to DL it? :confused:)
How do you know the launcher is really bundled in the download? Ticking the box could just download the latest launcher for you. (This is a guess though, I haven't download this)
No idea how it's set up yet, but imagine it's just same as Relive. Click it to install, it's in the installer.
Can't tell yet though, as I can't DL latest drivers :confused::)
Ah, got it DL'd.
It may be a DL to get it, file is similar to previous AMD installer.
Does anyone else have an issue with windows remembering where your monitors are with the new drivers. I have my screen stacked one on top of the other, but everytime i shut down my PC it reverts to putting them side by side and i have to manually go in and change them and apply new setting.
An other thing which may be unrelated is that AMD control panel and windows dont agree which screen is number 1 and 2 Window is correct but, AMD control panel switches them.
Both screens connected by DP.
Fixed in WHQL driver, Splendid
The WHQL set are lots better for me, was getting crashes in games with the beta set but the new ones are rock solid so far and I also seem to have gained around 1,000 firestrike points from them as well.
