Maybe, we'll just have to see. AMD had better hope Vega does well in upcoming AAA titles but even then it only really helps Navi, not Vega.Old tech? VEGA is top line in new technology right from the hardware. Only it's performance is matching Nvidia last year, but I honestly believe Vega needs new title to really showcase its full potential. Means waiting sadly
I agree but that's the price it was, so saying you'd be happy with a custom cooled card at £600 is insanity. £150 extra for a decent cooler??450 for a reference is way over priced and I would never buy a reference cooler from either company. Unless I was maybe water cooling it.
So their tests suggest an undervolted Vega 56 beats a stock 1080 whilst using less power. That sounds really nice but what about when the 1080 is undervolted and/or overclocked?LOLWTFBBQ:
https://translate.google.co.uk/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=https://www.hardwareluxx.de/index.php/artikel/hardware/grafikkarten/44084-amd-radeon-rx-vega-56-und-vega-64-im-undervolting-test.html&edit-text=
That review site actually tried undervolting Vega56 and Vega64 - why is the stock voltage so high??
Yes we played for years and years without it, because we never had it. But seeing and feeling how good it Is, why would you now go without adaptive...thats just daft, it's a game changer
I am also, my argument was not that it is not needed. My argument was why do people feel they are stuck when they buy a freesync monitor. I have had both, I never felt stuck and having to buy from AMD or Nvidia only. If one can afford expensive graphics cards, it is not too hard to sell what you got and pay a few hundred quid extra if adaptive tech means so much to the said individual no?Yer, same for me. I am a big proponent of Adaptive Sync tech, albeit I run a G-Sync monitor (PG348Q) and playing without it feels horrible. It is a game changer for me and the smoothness is something to be seen. My mate has a Freesync screen and plays just as well. I would happily buy a Freesync screen if AMD had a GPU that was worth it for me.
By TNA's argument, we should all go back to playing 1024x768 on CRT screens because we played for years on it just fine before higher resolutions ;D
At least I am not the only one that see's this. Must be a perception or people putting different value different things, thing. Like I can see a clear difference between 1440p and 4K, others cannot.I wouldn't say it's a game changer. I've got 3 PCs connected to my Freesync monitor but only one has Freesync, I can't say I notice a huge difference. I can often notice the one running the screen at 60Hz compared to the 144Hz ones (unless I use the 60Hz for a while and then I get used to it until I go back to 144Hz). But once your game is bouncing off the 144Hz/fps cap I can't tell much difference between Freesync on and off.
Yep. If nVidia added FreeSync support in a driver I would probably buy a GTX 1070 immediately.If Nvidia did that AMD would be dead, Freesync is the only reason for ever making a case for buying an AMD GPU anymore. I didn't want to buy Vega, but felt I had to due to being tied into Freesync. If it ever happened, Nvidia supporting Freesync I mean, then I'd gladly just drop AMD GPU's once and for all.
Huh? I never used to need adaptive sync because I had a 1200p 60 FPS monitor and could play games locked at 60 FPS. Now I have a 1440p 144 Hz monitor - why would I spend nearly a grand on a card and drop settings to low just to get smooth gameplay at 144 FPS when I can take advantage of adaptive sync and get a £250 card that can run games at 100 FPS?I don't get why people feel the need to buy AMD because of their monitor. Just sell the monitor and buy a G-Sync or just go without adaptive sync. It is not as big deal as some make it out to be. We happily gamed all these year before adaptive sync. Unless one plays competitively, then it is still in my opinion perfectly fine to game with v-sync on at 60fps locked. Plenty smooth for a single player offline game. Before people say anything, I have had both g-sync and currently have freesync. It is nice, but not so nice that it will force me to buy from one company.
The trouble is games are less demanding than stuff like compute so undervolting might not affect stability but if people run compute with too low a voltage you can get math errors. There's no way to tell really. Chip makers will generally go with a voltage that leaves some room for tolerance etc but if you remove that tolerance and get a minor dip in voltage you'll have errors happen.
Maybe they thought being competitive with nVidia in terms of performance at a similar price point (well with the initial launch prices anyway) was more important than dialling back the clocks to get into more power efficient territory. If they were clocked lower gamers could've overclocked them anyway to match the 1070/1080 and the default clocks would've looked much more sensible in terms of power draw and heat output, but the price would then have looked even worse.The thing is the Vega56 in its stock state is only slightly better than first generation Polaris in performance/watt - they really needed to stop worrying about 5% extra performance,and try to get over the whole hot and loud meme. They can't compete with the GTX1080TI so what is the point??
That's because when Polaris came out everybody moaned that AMD was wasting their time focusing on efficiency, nobody cared about power/heat, just make the best card you can, etc so with VEGA they prioritised performance over efficiency. Just like Polaris prioritised efficiency over performance because when Hawaii came out people moaned it used too much power and efficiency was just as important to them as performance.The Vega64 has worse performance/watt than many Polaris cards,and it makes AMD look even more stagnant technology wise for gaming.
Working fine in my Ubisoft games, but i know FreeSync is disabled in The Division due to flickering that cannot be overcome. The Application causes an erratic flip rate, causing the monitor to jump between the min and max refresh rate that unfortunately results in display flicker.
Basically people just like to moan and tech companies really shouldn't listen to most of it.
I wasn't accusing you of moaning more the consumer base in general. when AMD have noticeably higher power consumption than Nvidia people complain about it, when they don't people complain about it, they can't really win lol.Well I wasn't moaning about it AFAIK
Judging by that video alone, he sounds like somebody down the pub, who has read a little bit on Wiki and now thinks he's an expert
"I could never go back to a 60Hz, TN, non-curved, <10-bit colour, >1ms refresh with less than 10 USB ports and a cup holder for my coffee. Literally, never."I think either different people are able to perceive it differently or people value extra smoothness more than others. For me 60fps v-sync is smooth enough to play a single player game offline. Having g-sync or freesync on will not suddenly increase how much enjoyment I have at this point. So not I do not think it is daft from my point of view.
