So still way behind the 1950x. Cheers for the info![]()
hm, cool so how about this:
and hows your 10k 3dmark cpu score treating you?
nothing so professional, lower numbers till it crashes. probably why i dont have 1t yet![]()
One thing I've wondered with over clocking the ram, is do all you chaps / chapesses work all timings out in in Excel (As I have a spreadsheet with this in for mine) or do you use some sort of online calculator to bump to the timings?
Once you've done it for long enough, you remember the timing rules and what concessions need to be made, at least with the foremost secondary timings. There are static rules in place, once you exceed those the chipset will subsidise the arbitrary value with a working one (what exactly happens is anyone's guess here). Nobody here can really say they understand DRAM, just some better than others
Well then you bought the correct cpu didnt you?
the 7900x is also cheaper. or does that argument only work against intel when talking about the Ryzens?
CB15 synthetic? Lol.
It represents pretty much my exact usage scenario - 3DS Max and Blender - in which the 1950X also easily outperforms the 7900X.
Indeed. I spent countless hours (days) with DDR3 (Samsung Green ftw) and scouring forums. A lot translates across to DDR4, now i've spend more hours with DDR4 thanks to Ryzen requiring the effort. Good job i find it fun tbh.
As long as you are happy, i'm looking forward to seeing your 3dmark cpu score.I certainly did.
Hey, if you want the best, you need to pay for it![]()
Would be interested to see your full memory timings and aida bench if you have the time. I havent seen any other 7900x benches on it so im not sure what i should be shooting for! /amemorytimingnabIt's the finer tuning side to these new platforms for sure, even if the gains are slim.
I certainly did.
Nice one thank you. just got it stable too, now im forced to tweak some more!
Its a great platform, really nice to tweak and runs great. The temps prevent anymore than 4.8Ghz core and 33 cache, so inevitably ill delid it at some point, but for now its fine, gaming max temps around 65
