- 30 Mar 2017
I went to 1.45v, well just above, but no 4GHz for me! Oh well, I think I'll just stay where I am
Have a look at the memory. You can make some good performance gains.
Gigabyte just told me it's completely safe to use 1.5v with my motherboard and cpu combination! go figure.
vcore?
They replied to me saying....
Hello,
After checking with our team the CPU voltage can up to 1.50V.
Doubt your get that high tho as heat will be too much unless you have the best cooling system going.
igrone gigabyte with everything.
they are the manufacturer that believes, a 1800x at STOCK should be at 1.55V. yes my gigabyte gaming K7 at idle pushes 1.49V and at load seen it hit 1.55V
im running 3.9 at 1.368V at full load...
long day "ignore"igrone?
Argh I need 1.4 for the same oc![]()
well ive just decided to rag the hell put of the chipOh good, it's like that on all their boards thenAt stock, all-cores, mine sits around 1.26v under gaming load. If I fix the speed to 3.7ghz (the same as stock!), it prefers 1.406. XFR boost spikes it as high as 1.525 for brief moments. Reading around, I don't think those spikes are dangerous or even unusual, but probably unnecessary
My only bios option is offset, which I have down to -0.072v and it won't boot any lower so... yeah.
@smogsy that seems a sensible voltage for the speed you've got it atMost people are happy if temps stay south of 75, so I don't think you're even ragging it per se. If I let mine have it's 1.4v @ 3.8, it shoots up past 80 degrees within minutes and I bottle it!
But yeah I get what you mean about "weird voltages"... this is mine while gaming, stock with a small negative offset, all cores at 3.7ghz:
To be fair, I've never seen it reading above 1.5, and 1.4+ is usually in bursts of maybe 1-3 seconds and tied to one-core boost. Clearly those big spikes are very short and infrequent. It's possible that it's just a whole new paradigm on voltage use that nobody quite understands yet. What would really help is a statement from AMD giving not only the "safe 24-7" voltages, but the absolute peak XFR that they would expect to see. It's probably something higher than any of us expect and we're all worrying needlessly
Only cold boot issues I have are when I've dropped volts too low, and that really could be down to the "guess the offset" game that Gigabyte like to have us play. If I could actually specify say 1.3v @ 3.8, it might work out fine. /shrug
(And all grumps aside, 44-56 degrees when playing Ark Survival is lovely and cool)
...but when AMD say 1.45V reduce lifespan it doesnt make semse...
when the AMD profile sits my chip at 1.488V 24/7... (stock)
it could be just boards over compensating due to new chip not sure what a good level is yet... but not sure.That is exactly my problem. Ryzens exceed what AMD recommended at stock... would love to see them publish an article that explains it in unambiguous terms. The enthusiast crowd is too determined to peek under the bonnet to not be clued up.
*edit* Also, the VID changes on a whim anyway... and my VDD has now caught it up - though not exceeded.
the XFR is pretty pointless most of the timeDoesn't the 1800X boost up to 4.1ghz though? like I had said before I think AMD are already factory overclocking Ryzen so that it would be a lot more competitive with Intel, they could have probably shipped the chips at 3.4ghz using 1.2V vcore which was a much safer voltage long term.
