Deleted member 66701
So, this time round it's AMD with great marketing for their CPU's and it's Intel that are in disarray - loving it!
ClearlySo, this time round it's AMD with great marketing for their CPU's and it's Intel that are in disarray - loving it!
Depends how you look at. £1200 for a GPU that will hardly be good for a few years, vs a £2k CPU that will be good for many, many years. That makes the CPU look good valuenearly 2g for a chip, intel have lost the plot
Sad thing is, people will pay it. But we can at least thank AMD for forcing them to reduce the prices somewhat. imagine if Ryzen wasnt around. id say that chip would be closer to 3k.
@4.8 1.245v
, Gibbo has said week commencing 4th Sep
.Depends how you look at. £1200 for a GPU that will hardly be good for a few years, vs a £2k CPU that will be good for many, many years. That makes the CPU look good value
The cost of something not the same as the value.
Not cheap though !
I'm sure it will be worth the waitThanks
Thanks.
You guys got any 7-Zip or other productivity test done?
Still waiting on TR4 EK block, Gibbo has said week commencing 4th Sep
It's not quite the same because with GPUs you can really add more performance by doing the equivalent of "moar coars"; they essentially run heavily threaded applications. The same can be done for CPUs but it's overall less helpful than it is for GPUs.What? The CPU will have exactly the same performance today as 2 years from now, in 2 years you'll have 24+ cores at the same prices with updated faster architecture and better memory bandwidth. They will devalue in terms of ultimate performance just as fast as GPUs.
The supposed 80% extra performance that goes with a new process for GPUs goes for CPUs too, just because Intel hasn't been bothered to do it doesn't mean it can't or won't happen. Yet look what happened, buy a £1500 whatever the top end chip was called last time around, 10 cores, this chip has 80% more cores, though due to being same process node it won't have 80% more performance due to power, but remake that 18 core on 10nm and it will likely have 80-100% more performance than the 10 core chips and only 2-3 years later.
If you're gaming then you'll gain nothing going from 10 to 18 to 32 core chips, but if you're buying a high end chip for multi core performance because you need that performance, then you'll absolutely gain massively in the space of a couple of years.
If Threadripper wasn't around, we couldn't have anything more that the 7900X
How is that exactly as helpful? All games will be faster with a GTX 1080 over a GTX 1070 (even if they had the same core and memory clocks). Not all games or applications will be faster using 8 cores instead of 4. Thus, it is easier to advance GPU performance when reducing transistor sizes than it is for CPUs.It's exactly as helpful on cpus, there are two groups of people who spend £1500+ on a multi core cpu, people who game, benchmark games and some basic applications and generally wasting their money and those who actually use applications that use all the cores well. The former might be 0.0001% of all 10+ core cpus, the later, making up the bulk, will see amazing performance scaling from more cores.
