interesting, curious what this hot spot turns out to be; seems like it's VRM related with the crazy temps you can get with air coolers!
VRM for GPU/HBM have temp limit in PowerPlay posted here and OCN. On Fiji when either reached GPU is throttled.
Fiji didn't have a HBM IC temp limit in PowerPlay but VEGA does.
The temp points for HBM general performance lowering based on temp are not in JEDDC PDF. There are several 'trip points' that can be set, so best is to cool as much as you can for max performance gain always.
