I thought the whole point of a sealant is it makes wheels easier to clean
I haven't tried it but will report back when I do.
well yes but what I'm saying is that from my pov hydro2 doesn't make much of a difference.
because rather than using the wheel cleaner which would involve -;
spray on
agitate with a brush if required
pressure wash off
you'll do
pressure wash
wash with a wheel mit + shampoo
scrub all the hard to reach areas
pressure wash again
what I'm saying is that you'll end up spending more time/putting more effort in for the same result.
with my wheel style I'd be at it for 10 minutes before each hard to reach area got cleaned.
