The RX Vega 64 Owners Thread
What the hell is this stutter lag on just browsing the internet and scroll fast down all about ? I did a clean uninstall using DDU and put on the latest 17.8.2 drivers. Also feels like my system is about to lock up ? Anyone else got this
turn off hardware acceleration in your internet options for the time being...An old bug that seems to have re-surfaced.
seems theres a bug that we discovered in the 56 owners thread, whereby the boost clocks are not fully being utilized from the powerplay states, did you check boost clocks during the run, do they match what they should be. if not try custom and setting the stock clocks manually and re running your score, do you get the same sort of results? obviously this is on the 56 and not the 64 this may not apply in your scenario. hope this helps.
Right it is reporting boost 1630Mhz according to Heaven , but I'm getting around about the 1550-1570Mhz range according to Wattman , this is on the Turbo preset on Wattman as well. Still getting about 2100 score on Heaven which far about 650-700 points down vs a 1080 , expected more , but I guess it is what it is.
Just done a 20 minute bench of Firestrike, with a few overlays on screen for you guys to see what settings I'm at for future reference if needed. I've now dropped my core and voltage a tad for definite stability, this will be final 24/7 settings for gaming now. I've benched at 1750/1100 so at 1700/1080 it's given it a bit of breathing space.
I'm very impressed with the absolute solid core and memory clock speeds, just no dips or fluctuations at all. Interestingly only 63c on the Hotspot in GPU-Z and a max core temp of 39c and max HBM temp of 40c.
click for a big one :)
AMD doesn't do great on Heaven anyway, so yeah ... not much to be done about that.
Just done a 20 minute bench of Firestrike, with a few overlays on screen for you guys to see what settings I'm at for future reference if needed. Dropped my core and voltage down a tad now, this will be final 24/7 settings for gaming, benched at 1750/1100 so I know I've given it a bit of breathing space now. I'm very impressed with the absolute solid core and memory clock speeds, just no dips or fluctuations at all. Interestingly only 63c on the Hotspot in GPU-Z and a max core temp of 39c and max HBM temp of 40c.
Wow I've never managed to get my clock speeds that solid on the 17.8.2! Do you think it's because you lowered state 6? Must give that a try. Is that the normal Firestrike you used?
Wahey!
click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click,
click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,
Wow I've never managed to get my clock speeds that solid on the 17.8.2! Do you think it's because you lowered state 6? Must give that a try. Is that the normal Firestrike you used?
It does seem better lowering the state 6 clock and voltage, big thanks to the guys that mentioned it in here a few pages back. Previously I was running 1750mhz @ 1200mv on both state 6 and 7, and it seem to hit the ceiling and downclock more often. With these new settings, its a real joy in gaming.
Wahey click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click,
click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,, click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,click, click, click,
lmao...puts my big one to shame :)
Just done a 20 minute bench of Firestrike, with a few overlays on screen for you guys to see what settings I'm at for future reference if needed. I've now dropped my core and voltage a tad for definite stability, this will be final 24/7 settings for gaming now. I've benched at 1750/1100 so at 1700/1080 it's given it a bit of breathing space.
I'm very impressed with the absolute solid core and memory clock speeds, just no dips or fluctuations at all. Interestingly only 63c on the Hotspot in GPU-Z and a max core temp of 39c and max HBM temp of 40c.
click for a big one :)
I see you're using the new GPU-Z 2.3.0 so just downloaded it. All the missing information is now present and correct yeah.
I agree it's poor and feel really sorry for all those, yourself included, that was let down with a faulty card - I was lucky that mine is fine but do we actually know for sure it's an issue with C0 chips or are we just speculating based on snippets of information? Has there been an official comment from AMD on the volume of faulty cards or has anyone actually confirmed what the fault on the cards has been yet?
Speculating from what I hear, That said there was gossip about a delay due to needing to do a new stepping a few months back but I don't really understand it all so I could be way off.
Sweet card and OC :) , thanks for share :) .
Damn envious for sure ;) .
Enjoy :) , BTW neat WC rig as well :) .
It does seem better lowering the state 6 clock and voltage, big thanks to the guys that mentioned it in here a few pages back. Previously I was running 1750mhz @ 1200mv on both state 6 and 7, and it seem to hit the ceiling and downclock more often. With these new settings, its a real joy in gaming.
So I just tried to match your settings although I put state 6 at 1602 as my default state 5 is higher than 1537. I got a solid clock but only up to 1660. I wonder if I need a bit more voltage given mine is the AOI card - certainly more scope to experiment... I thought I was done with benching too! :rolleyes:
Edit: Left the voltage at 1100 and 1150 but increased the clocks to 1652 and 1727 and got a solid 1680...
Back to stock clocks of 1677 and 1752 and getting a solid 1700 - seems it is the voltage that is causing the clock fluctuations...
Are your clocks behaving the same during gaming or other benchmarks aside from Firestrike @TonyTurbo78 ?
thanks Gup, nice of you to mention.
@heartburnron there is no end to overclocking....tomorrow I'll look at it and think, I know I can go much higher, time to tinker...I'm the OC tinkerman :)
I know mate, I can't resist it myself but it's just the amount of time it takes - those blasted 3DMark benches take around 10 minutes every time - I was going to play Dishonoured 2 between 10:00 and 11:00 tonight but I've just spend the past hour running benches. Keep us in the loop if you do manage to squeeze anymore out of it, I'm going to try and get an hour or so of gaming in before bed time...
Edit: I just increased the voltage there up to 1125 and 1175 and ran Firestrike again to see what would happen - the clocks dropped to 1680...
Edit: Couldn't resist one more test - ran Timespy with the lower voltage and got my highest ever graphics score - 8149. Thanks again for sharing Tony, wouldn't have tried that myself.
