Nuclear War! What would you do?
You forgot to mention that the new bus station they built, just across the road from the old one, is a.) way too small for the busses to operate safely from, b.) located in a place whereby said busses have to navigate through small winding backstreets to gain entry and to leave and c.) is generally just not fit for purpose.
Local government corruption at it's finest.
How about the old bus station being that run down and derelict it was used in an apocalypse movie called The girl with all the gifts. 80% of S-o-T is a **** hole.
Hope that all that time playing Fallout games wasn't wasted, after all.
Having just purchased a new Kia, hope the spares aren't made in SK or I'm cussed, come service time.
The bomb was specifically detonated in a way not to cause damage (as with all tests).
If you dropped a full size Tsar bomb on the middle of London then the inner city would be vaporised, most buildings inside the M25 would be leveled and most people injured or killed, and everyone east of Newbury and south of Cambridge would suffer third degree burns. You're looking at around six million dead and another six seriously injured. And this doesn't touch on the fallout or nuclear winter.
The reason people compare bombs to the Hiroshima and Nagasaki ones is because those were the last ones properly detonated.
It would destroy most of London agreed . But again you are comparing to Hiroshima bomb and calculating the damage against that . Observers 60 miles away could feel the heat of the bomb but it didn't burn them .And a 100 megaton bomb is impractical as most of the energy would blast off into space . But those weapons are history and were only made as they couldn't hit a target and missed by miles .Now they can put a missle through a front door and they are just not needed
so you don't think something w/ the ability to do damage SIXTY MILES AWAY is impressive? consider what was happening 10, 20, 30 and 40 miles away and then look at those distances on a map. Sixty miles away, and it's causing structural damage, and probably a lot of wounds/deaths from shrapel/blunt force trauma from flying glass and doors.
Of course its impressive . People dont understand the way nuclear bombs damage is calculated and always do so against little boy and fat man .Like i said just because its X amount of times more powerful does not equal that same amount of damage . 60 miles away doors and windows were blown in the houses were not destroyed ,many think this bomb destroys everything in 100 mile radius or something when that isnt the case
There's a secret underground nuclear bunker near to me. Or at least, that's what the sign post says. I'd probably head there and hope they let me in.
I'm not that's just the predicted effects that bomb would have on London/the south east. The reason most predictions mimic the effects of the Hiroshima bomb but bigger and not a random test on some remote island is because that's a real world use and so a real world detonation of a more powerful bomb follows that style.
But 90 percent of the buildings in those Japanese cities were wood framed buildings so the damage was far greater . The bigger bomb doesn't equal bigger damage and nuclear weapons designer will tell you exactly that .
Plus, I would imagine it's highly unlikely the USA would launch a nuclear weapon, even if NK launched one.
Instead, I'd expect a conventional strike to take out all of NK's offensive capabilities, then they'd take out all of the command and control centres.
Basically, how they did Iraq. I expect the majority of the army would gladly surrender once the command structure is defeated.
If the blast radii are bigger then they engulf more things and more people, more things and people hit equals more damage.
The tsar bomb was 3000 times more powerful than the Hiroshima bomb that destroyed just under 4 square miles of the city . 4x 3000 = 12000 square mile and thats my point people calculate the damage via this method when its completely wrong .
Well, yeah that's correct, but why are you ranting at me about it when I haven't done anything like that? lol.
The Tsar bomb had a total devastation circumference of 22 miles.
Plus, it was so heavy that they had to completely gut an aircraft to be able to hold it, and the crew of that plane only just survived the blast themselves. So in reality, it's not really a likely combat weapon - or something you'd expect to be fired on the tip of an ICBM.
I would find a large wall that seemed sturdy enough to survive the blast, and then I would adopt a classic 'Walk Like An Egyptian' pose and await immortality as the grooviest nuclear shadow there has ever been.
