Nice score! ... Could an older cpu affect the graphics score?
Thanks! Was quite surprised.
Also, not sure, I think the CPU only affects the physics & combined score?
Depends if the cpu is old enough to cause a bottleneck situation.Thanks! Was quite surprised.
Flashed the stock bios and got same score, which confuses me. Everything on paper should be slower but its the same graphics score. Core drops about 70 mhz from the vega 64 bios and mem drops 150 mhz.Thanks! Was quite surprised.
I'll test this tomorrow currently on 64 bios, just managed to get a 23k firestrike scoreAnyone tried running Unigine Superposition benchmark? For some reason my GPU only maxes out at around 1300mhz when it should be around 1500mhz.
Anyone else having similar issue?
I'll test this tomorrow currently on 64 bios, just managed to get a 23k firestrike score![]()
Btw the benchmark was run on 1080p extreme.I'll test this tomorrow currently on 64 bios, just managed to get a 23k firestrike score![]()
ive just tried it and my gpu was around the 1550mhzAnyone tried running Unigine Superposition benchmark? For some reason my GPU only maxes out at around 1300mhz when it should be around 1500mhz.
Time Spy and Firestrike both push the GPU around 1510mhz
Frequency 0%
PL on +50
Voltage 1000/1000
HBM 920mhz
Fan and temp on default
the 56 is the gift that just keeps on giving, well pleased with my £380 purchase
Just watched this. Should make 56 owners happy
target temp is 75c and I set the fan at 2800rpmWhat is your fan and temp set to?
I'd boost power to 50 and undervolt to 1050mv on vega 64Anyone know how to calculate the power draw? im trying to work out the best performance to power draw.
on the Vega 56 Bios
Gpu Clock = +4%
Gpu MV =1050 stage 5 & 6
Mem = 945
Mem MV = 900
Target temp Max = 85
Min = 75
Fan speed Max = 3000
Min = 600
Power = 50%
or on the Vega 64 Bios
Gpu Clock =1532+1592 5 & 6
Gpu MV =1100 stage 5 & 6
Mem = 1000 ( cant go higher get hard crash)
Mem MV = 900
Min = 75
Min = 600
Power = 10%
Both score around 7000 in Timespy. I could push further with the Vega 64 bios but I feel this is a happy medium between noise/ performance
1080 extreme is the stock demo run for firestrike right?Also what are your voltage, ram, oc settings and was it run on 1080p extreme?
thanks
settings areAlso what are your voltage, ram, oc settings and was it run on 1080p extreme?
thanks
Here is what I get with 1080p Extreme. My card doesn't go above 1300~mhz. Will try 1080p medium, high etc see if it does the same thing.
