i cant imagine having to go down 8 gears to blast out a corner is very fun. in a manual you go from 5th or 6th straight to 2nd if you like.![]()
Kickdown my friend.
350 is my new all time favourite looking one, 350 hood, bumper and fenders will come for MY18 GT as they have done for MY15 so could just replicate that like my buddy did with his yellow one.![]()
I've never being blasting through a corner in 5th or 6th then needing to drop to 2nd, as Para says you best get some driving lessons.
Also the box has 7 acceleration gears, 3 overdrives. In manual mode (paddles) I suspect I shall simply just always be one gear higher than you'd normally be due to short ratios, this is also great because when you have paddles its actually more fun the more you use them, its one of the reasons I shortened the ratio on my M3 so I could smash through gears more and enjoy better acceleration. Also with an auto in manual mode, just pull the paddle twice quick to drop two gears in one go, but as said any good driver would be in the right gear before corner.
Pop down the gears under braking before the corner.Indeed, if it was such a problem with sequential gears than motorbikes would be buggered!Pop down the gears under braking before the corner.
Exactly, extra man points for doing it properly with heel toe downshifts![]()
no doubt you will get it looking great.
i still think this is the best looking mustang.
Which mods are you taking over from your current car if any @Gibbo ?
he doesn't even own it yet - ban! (Should this level of detail not be in the Mustang thread??![]()
)Is that a diesel or the Cupra? I keep looking at the Cupra versions of these can get a 10yr old one now easy for 6k and they all remap so well.![]()
Got my stage 2 map done. Great service as always from the shark performance lads.
Have you had any faults with yours in general?
What are your 0-100 km/h times now?![]()
Are you coming then?Stage 2... You cheat, you'll beat me at pod now. I'm out!![]()
