- 13 Jun 2011
An indoor smart cycling trainer....... for the bad weather days/evenings
Needs a red traffic light so can practice carrying on thru it
AS5 and a rather expensive thermal pad.
Decided to redo the thermal paste on my laptop's CPU and GPU, because as you can see Dell clearly didn't give a crap.
How loud are these things? Would you be able to get away with one in a bedroom above a living room at all?
You've clearly not used a trainer lol they were trying to work on VR Zwift, but it's trying to do it in a way that you're not sweating on everything. You sweat like MAD.That training setup is screaming for a rift/vive to be honest.
Yeah I figured that but seeing as PAL died years before the camera was ever designed and it's designed for HD/4K photo video it's kinda crazy that it uses 90's style FPS lol.That will be because in 25 fps was historically the standard encoding for analogue tv - PAL.
Sadly not quite £50Daahcams are a piece of tech I really advocate having, amazingly useful and such a good safeguard against insurance scammers and other road idiots, £50 can end up saving you a lot of money if you had an accident.
I hardwired one of those intothe wife's car, well two now (Evoque now 911), really good bit of kit and has come in handy on a couple of occasions. Recommended.![]()
The 2 ch kit for front and rear view.
Andi.
The Tacx Neo being a electromagnetic resistance unit is as loud as your bikes chain gear. Fans would likely be louder. The Neo also simulates road surfaces so that might pass through the flooring so a thick mat would helpful.
The cheaper Vortex unit and other entry level SMART trainers have fairly loud roller resistance units so not ideal in that situation.
New camcorder with high quality 4 track audio.
