You just misunderstand how poor the rest of us are, that £2 would make all the difference to us sub £1000 per week peasants.You must have me mixed up with someone else as that’s only the 2nd time I’ve mentioned it.
They must be considerably richer than yow
Thanks for reminding me as I knew there was something i forgot to buy for itDo you have a fire resistant case for it?![]()
Crikey, that's gorgeous! I will have to go looking for one now.
It's very understated but when you look at it in the flesh, you can't help but stare!
I thought my Oak logs were on damp side so got this to check - seem ok at 15%
.Every man needs a moisture meter
Where's the strap from?
I was going to, but then you went and called the dial a "face" and I got triggered
It's the Ahoi Atlantik, I have three straps for it, the red posted, a black version and the two piece that came with it.
