Good work & well done! Tough ain't it!Got an ftp done through Zwift:
So you've got a pass yet you're holding off purchasing... Que?!Bah, I got a pass from the revenue protection officer for one gadget. Wahoo Kickr or Power meter. The Tacx Vortex is pretty decent, so PWM it is. I'm going to go for a Vortex 3 when its properly released.
I wouldn't worry too much about losing weight, for you predominately riding on the track weight has less issue (unless you wanted to ride more hills!). On the track you're best training peak power & active recovery for the sprinting and efforts out of corners (and then recovering from it). Sweetspot as well will be good for you - threshold riding of constant power much like the FTP test, but usually for shorter periods.
Ok thanks. Your road choice isn't vastly different to mine so I may have to do the same, just £££!
Did you try/consider any cheaper alternatives? How do you find the Sitero when riding in 'normal' position? Enough relief?
Sadist!I've decided to enroll in next seasons senior/vet track league - for fun.![]()
That was a great price for the Sitero and around the budget I'd set myself. May try and snipe one (or the Tritone) as they both look to sell S/H well at ~£100.Found the Sitero on the bay new from a Cash Converters for the same price I paid for the Tritone, £70 so not particularly expensive, bought that in Jan from Wiggle so that's going back as it's unmarked. Bike came with the Ardea Tri (Speedmax) which wasn't too bad but need a relief channel or to point it down a bit which I didn't try as the covering was like sandpaper anyway.
'Normal' position is on the extensions and it's fine. On the bull-horns or more upright, which you wouldn't be for long, not so much. As it's got straight edges so doesn't contour the same way as a regular saddle. Posted pictures in the Aero Thread I think.
It's probably the latter, once you're more used to the turbo (as now) you'll test better as more naturally relaxed and comfortable there. I was similar with my FTP test - very little sessions before so think that was the cause of my poor result.Even yesterday doing 5 minutes at 195w, my HR didn't go above 125 which is still Z2 for me, and it felt very comfortable. I don't know if it's because I've been consistent since doing my FTP test, whereas when I did the test, I'd only done 2 zwift sessions beforehand and previously had 10 days no training at all.
Sadist!
At under 70kg you really don't need to worry about weight before power. Maybe once you're pushing your FTP around 300W and want to do some long climbs it's more suited, but I wouldn't worry at this stage (winter is coming!)
Id already decided any riding this weekend would be indoors (baby due sunday so I'm just getting some brownie points in the bank!)![]()
I'm really starting to think something was up during my FTP test
By normal I'd meant hoods, forgot you mostly rode the speedmax on your trainer! I think the aero thread is where I saw your picture comparing the two. Thanks for the info and comparisons!![]()
Lots of riders will 'lose' power when riding on the trainer/indoors, just because it's different. A little bit of conditioning and riding you'll soon see it come back up. I've actually found my threshold/VO2max higher on the turbo as I can bury myself without worrying about balancing/steering/looking where I'm going! I've got a great pain face selfie I'll put up on my last FTP test from immediately afterwards. Didn't quite throw up this time but have been known to!A combination of more turbo time and getting used to riding the trainer ( and ERG mode) will have helped.
Thanks guys, any recommendations? I'm currently looking at the Selle Italia SLR Flow.I wouldn’t put a sitero on a road bike. I bought one for my TT used as it was cheap to see what I thought.
It’s quite big and flat, good cutout and it’s alright for the TT position but I wouldn’t be comfortable sat further back on it for a long time.
Setting up my trainer for the first time.. How hard should the roller press against the tyre?
You don't want to be wheel spinning on the roller when you are cranking up the hurt
