Does this mean OC open all their 8700k's and test them to see what speed they will hit, and then bin them accordingly, or do they only open a percentage of incoming stock?
No they don't but the work and cost of binning, then deliding then retesting the delid is costly and time consuming.
These products are effectively uprated Intel models normally stock is 4.7 with these stock is 5g+ with upto 25c better thermals and full warranty.
5.2 cpu are one in 30 so an average end user has to invalidate the warranty delid 30 cpu's to find one.
We normally only test oem system stocks but because of low stock and indeed no stock for systems we binned all retail to fulfill these areas of our business.
Yeah that simple 55 ratio all cores, cache 4.4 xmp even set 1.4v and llc then your totally assured testing is 1.35-1.4V. Use it.....
If we offered it for free they would all buy.
I still say you should have it as a service on the tray CPU SKU's, for £30ish, but not binned, just de-lidded. I mean who really cares about a one year warranty on a product that very rarely goes wrong unless you mishandle it.
as long as you aren't binning them all and simply putting the 'normal' ones back into retail stock, people can pay their monies and take their chances![]()
I've watched a few reviews and they were showing over 20°C difference after delid and use Thermal Grizzly Liquid Metal.So what temps were you getting before the delid and after the delid?
I'm not buying, only bought my 7700k a few months ago......yeah i'll tell myself that for a few weeks anyways.
