Luxury![]()
700..Must be close to £800 with head !
700..
Wow that looks like a serious bit of kit Jonney, I'm still rocking a Red Snapper and thought that it was expensive. Which actually used for the first time this year last weekend.
Bought a cheap £5 remote trigger a couple of days before, mounted the D4 on the RS and had the trigger in the left hand and leaf blower from my shed in the right. Had a right old laugh with the B&G.![]()
That's good if you only have 1 tripod I guess. But for me, I wouldn't like it because
1 - it only folds down to 43cm, that is 50% longer
2 - it goes up to 143cm. Sometimes and I have, used taller with my Manfrotto 055Pro
So for travel I compromise on the compact size for the extended height whereas for shoots I put it in my car so weight and compact size doesn't matter. It makes sense to have 2 different ones. If its 43cm I wouldn't take it abroad as it's a bit too long and I wouldn't use it for shoots because it is too short.
For travel as long as it is under 60cm I don;t really care. You can't travel with a tripod in the cabin (nearly has one confiscated but luckily had time to go and check it in after security refused to let me pass). On a backpack it doesn't really matter as I attached it to the outside of my F-Stop Lioka. When going really light I just prefer a monopod or a bean-bag on top of my backpack.
Yea it can fold very tiny.That's good if you only have 1 tripod I guess. But for me, I wouldn't like it because
It only waeighs 0.3kg heavier then yours and not bad
Trust me i have hiked all over the world with it.
